Old 06-06-2005, 04:17 AM   #1
WolfDrive
Member#: 49506
2004 Impreza WRX STi
Java Black
Default Hit fuel cut... should I raise it?
I've got a TD06/20G with catless TBE, perrin injectors, walbro fuel pump, BigMAF intake, APS FMIC, STi UTEC, etc.etc...
Recently I've been hitting fuel cut a lot -- it's set at 24, though I seem to be hitting it ~20 (according to the logs). [my EBC read 24.2psi] My IDC's seem fine and dandy at 55-60 -- though I dont know why at the end of this log clip they hold at 59.3 -- and I'm getting zero knock throughout the map...
sooo is it safe to raise the fuel cut ? BTW: running on 93 pump
Code:
 3095, -3.6,2.4, 22, 00,   00,  +46.0,   8.7,ECU. , -1.0,ECU.  ,2.3, 14.65
 3135, -4.0,2.3, 21, 00,   00,  +46.0,   8.1,ECU. , -1.3,ECU.  ,2.2, 14.83
 3132, -5.1,1.7,  0, 00,   00,  +38.9,   7.6,ECU. , -1.0,ECU.  ,1.5, 15.08
 3092, -6.7,1.5,  0, 00,   00,  +31.8,   7.6,ECU. , -0.8,ECU.  ,1.4, 13.45
 2981, -8.7,1.5,  0, 00,   00,  +25.6,   7.6,ECU. , -1.8,ECU.  ,1.4, 12.37
 2705,-10.2,2.0, 23, 10,   00,  +35.5,   7.0,ECU. , +2.2,ECU.  ,2.3, 13.12
 2467, -9.6,2.4, 27, 10,   00,  +44.6,   9.7,ECU. , +2.0,ECU.  ,2.4, 14.18
 2447, -7.3,2.4, 28, 10,   00,  +42.1,   9.8,ECU. , +2.0,ECU.  ,2.4, 14.74
 2485, -5.1,2.5, 28, 10,   00,  +41.6,   9.9,ECU. , +2.3,ECU.  ,2.4, 15.18
 2519, -2.8,2.5, 28, 10,   00,  +39.8,  11.0,ECU. , +2.5,ECU.  ,2.5, 15.31
 2554, -2.0,2.5, 28, 10,   00,  +39.4,  11.3,ECU. , +2.4,ECU.  ,2.5, 15.02
 2592, -1.8,2.5, 28, 10,   00,  +39.7,  11.5,ECU. , +2.3,ECU.  ,2.5, 14.83
 2635, -1.6,2.6, 28, 10,   00,  +39.4,  12.1,ECU. , +2.3,ECU.  ,2.5, 14.87
 2668, -1.4,2.6, 29, 10,   00,  +39.3,  12.0,ECU. , +2.2,ECU.  ,2.6, 15.02
 2723, -1.0,2.7, 32, 10,   00,  +36.7,  13.8,ECU. , +2.1,375.00,2.6, 15.12
 2791, -0.2,2.8, 33, 10,   00,  +34.8,  15.6,ECU. , +1.8,375.00,2.7, 15.24
 2812, +0.6,2.8, 33, 10,   00,  +33.8,  16.0,ECU. , +1.3,375.00,2.7, 14.49
 2878, +1.5,2.8, 33, 20,   00,  +33.8,  16.7,ECU. , -0.3,375.00,2.7, 13.65
 2952, +2.1,2.9, 35, 20,   00,  +34.3,  17.6,ECU. , -0.6,375.00,2.8, 13.47
 3033, +2.9,3.0, 35, 20,   00,  +33.6,  18.8,ECU. , -1.0,375.00,2.9, 13.50
 3089, +3.7,3.0, 38, 30,   00,  +33.4,  19.2,ECU. , -2.1,375.00,2.9, 13.23
 3171, +4.7,3.2, 45, 30,   00,  +31.5,  22.2,ECU. , -2.7,375.00,3.0, 12.99
 3248, +6.4,3.3, 47, 40,   00,  +25.9,  24.2,+23.0, -3.5,375.00,3.0, 12.96
 3333, +7.8,3.4, 48, 50,   00,  +23.6,  25.5,+17.0, -2.8,375.00,3.2, 12.61
 3439, +9.6,3.5, 48, 50,   00,  +19.7,  30.0,+17.0, -2.9,375.00,3.3, 12.14
 3505,+11.7,3.7, 45, 60,   00,  +15.7,  35.9,+16.0, -1.4,375.00,3.6, 11.68
 3667,+13.9,3.9, 44, 70,   00,  +12.0,  43.7,+14.0, -1.5,375.00,3.7, 11.14
 3792,+16.8,4.0, 42, 90,   00,   +9.3,  49.8,+14.0, -1.7,375.00,3.8, 10.86
 3898,+19.6,4.1, 38,100,   00,   +9.0,  49.7,+14.0, -2.0,375.00,2.8, 10.48
 4480,+20.2,3.8, 36, 90,   00,  +20.1,  55.3,+15.1, -3.7,375.00,3.8, 11.30
 4030,+17.0,3.2,  0, 00,   00,  +23.7,  59.3,ECU. , -6.0,ECU.  ,2.5, 11.30
 3770, +9.6,2.2,  0, 00,   00,  +23.5,  59.3,ECU. , -4.6,ECU.  ,2.1, 10.96
 3415, +0.8,2.1,  0, 00,   00,  +23.7,  59.3,ECU. , -2.8,ECU.  ,2.0, 12.99
 3245, -6.1,1.3,  0, 00,   00,  +23.7,  59.3,ECU. , -1.8,ECU.  ,1.2, 14.92
 3046,-10.2,1.3,  0, 00,   00,  +23.7,  59.3,ECU. , -0.4,ECU.  ,1.2, 14.87
 2754,-11.0,1.3,  4, 00,   00,  +24.0,  59.3,ECU. , -0.3,ECU.  ,1.3, 19.71
 2460,-11.0,1.4,  0, 00,   00,  +23.9,  59.3,ECU. , +0.0,ECU.  ,1.4, >25:1
WolfDrive is offline   Reply With Quote
Old 06-06-2005, 09:23 AM   #2
west005
Member#: 65684
1993 JDM Soarer TT
White on golds
What EM? TurboXS and some others sell fuel cut defender. Asking them would be safer. Call TurboXS, Nathan is pretty cool and should be helpful.
Later
E
west005 is offline   Reply With Quote
Old 06-06-2005, 09:28 AM   #3
Davenow
Member#: 23676
Later
E
he said utec
and the utec doesnt need a fuel cut defender, its built in.
Old 06-06-2005, 09:32 AM   #4
west005
Member#: 65684
1993 JDM Soarer TT
White on golds
I did not open my eyes, but yeah I would call TurboXS VS NASIOC posts. Unless one of the tuners jumps in.
Old 06-06-2005, 09:33 AM   #5
happasaiyan
Member#: 37731
change your UTEC boost display to "gauge".
you will see that you are actually running 24psi. so...if its safe right now, then sure, go ahead and raise it.
happasaiyan is offline   Reply With Quote
Old 06-06-2005, 09:42 AM   #6
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
The MAP sensor is slow in UTEC logs. You're probably hitting 24psi, but not long enough for it to show up in the logs. Is there a problem with your wastegate? You may have blown a hose off the wastegate actuator, which would cause the behavior your seeing - it'll overboost all the time. Double check your hoses. If they're fine, you have to decide how much boost you're comfortable with, and set your boost map (or other boost controller) accordingly. I would set fuel cut for 1-2psi above what you plan to peak at. If you plan to peak at 20psi, set fuel cut for 22psi, etc.
The ECU shuts off the fuel pump at 0% throttle when you're coasting down, and it leaves the IDCs at whatever their last value was, so it's normal for it to say 59.3 the whole way down. Note that your AFRs will go to >25:1 since there's no fuel (no actual combustion happening).
serendipity is offline   Reply With Quote
Old 06-06-2005, 09:45 AM   #7
serendipity
Member#: 54597
08 'Busa, 08 ML63
He is displaying gauge - there's a bug where it always says psia. Note the negative values when he's in vacuum
Old 06-06-2005, 10:29 AM   #8
wrex03
Member#: 29963
04 sti
Your "cars" timing is very low in this range (3600-3800). Is this were you normaly hit fuel cut?
Code:
wrex03 is offline   Reply With Quote
Old 06-06-2005, 12:00 PM   #9
x99percent
Member#: 27108
2004 STi
2004 A4
I'm not sure if you've done this already or not, but FYI:
You need to flip the FCD switch on the UTEC if you want to run >20psi, because the factory ECU is shutting down the fuel pump in an attempt to stop the overboosting.
The switch corresponds to two settings for the UTEC's hardware FCD.
1 - Move the factory fuel cut from ~17psi to ~20.5psi
2 - Eliminate the factory fuel cut altogether.
This switch has *nothing* to do with the UTEC's software-based fuel cut in the OLF parameters.
x99percent is offline   Reply With Quote
Old 06-06-2005, 12:05 PM   #10
serendipity
Member#: 54597
08 'Busa, 08 ML63
Good catch - I forgot about the UTEC's toggle switch. That's probably what he's hitting.
Old 06-06-2005, 12:32 PM   #11
happasaiyan
Member#: 37731
if the FCD isnt turned on, your car will just run lean. it wont feel like a typical fuel cut.
ie- if software boost cut is > FCD, when FCD boost cut < current boost < software boost cut, you will run ridiculously lean.
when i was setting boost higher and tuning for the higher boost, before i flipped the FCD switch (or even knew i had to), i had the software boost cut at 25psi...and was running 22-23psi...and 13:1AFR (when it would shut off the fuel pump). this doesnt look to be the case here.
also- before i switched my UTEC boost display to gauge, it would only show 19-20psi or so...then set it to gauge, and voila 22-23...which is what my defi boost gauge had been showing me all along.
Old 06-06-2005, 12:57 PM   #12
wrex03
Member#: 29963
04 sti
I had the same issue...
Slight boost creep, not enough to hit fuel cut, should I be concerned? Rizen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-28-2007 11:22 AM
Hitting Fuel Cut and Boost cut at 18 PSi HELP!! ChrisV-FL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-11-2002 10:36 AM
What max RPM do you hit fuel cut in your wrx? Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-24-2002 03:50 PM
What RPM do you hit fuel cut? Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-24-2002 02:33 PM
is hitting fuel-cut bad? okamikatekore Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 01-13-2002 01:35 AM
