Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 06-06-2005, 08:42 AM   #1
ACLerok
Member#: 27915
2004 Subaru WRX STi
Default perrin O2 simulator and inspection
I was wondering if anyone in NJ put their car through inspection with the perrin O2 simulator.. did you pass??
i got a turboback now and i'm thinking about getting one in hopes of passing inspection. any help would be greatly appreciated
oh and btw, what really sucks on my part is i was given a one year sticker instead of a four year.. can i change that?????
ACLerok
stealing your girls' hearts one at a time in Jersey...
ACLerok is offline   Reply With Quote
Old 06-06-2005, 09:32 AM   #2
Panic
Member#: 48699
2008 Evo X GSR
Apex Silver
To answer your first question, I believe the perrin 02 simulator is an electrical fix for the CEL which means that you will not see the CEL but that the sensor will be reading as not ready which means that you will fail OBD II testing.
Do a search for mechanical cel, this uses some spark plug adapters to move the sensor away from the exhaust flow so that it will read a temp difference and not throw the CEL.
Next question, if you bought the car new I would go back to the dealer and see what they can do for you about getting you the correct inspection schedule.
Good luck.
-Peter
Panic is offline   Reply With Quote
Old 06-06-2005, 12:20 PM   #3
ACLerok
Member#: 27915
2004 Subaru WRX STi
well i know that when i go to the inspection station, they plug into the OBD. wouldn't that mean that they check emissions electrically? i dont all too much so i wouldn't want to go on any further...
Old 06-07-2005, 10:45 PM   #4
ACLerok
Member#: 27915
2004 Subaru WRX STi
anyone have any insight on this?
Old 06-07-2005, 10:55 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The OBDII testing involves the inspector plugging a scanner into the diagnostic port to check for stored codes and OBD "readiness test" status. If the CEL is on, there are any codes stored, or the readiness tests are not complete the car will fail.
As Panic said the electrical (wired-in) CEL fixes are known to interfere with the readiness tests even though they do eliminate the CEL, so if you are in a state that does OBDII testing such as NJ or NY you should NOT install one of these fixes. Do the mechanical fix instead.
Old 06-07-2005, 11:34 PM   #6
ayim01
Member#: 83875
02 impreza wrx
aspen white
youre allowed to fail just one obd test. itll most likely be your evap so get your o2 all corrected.
ayim01 is offline   Reply With Quote
Old 06-08-2005, 01:09 PM   #7
ACLerok
Member#: 27915
2004 Subaru WRX STi
ok so the perrin sensor is a bad idea?
then what can i get done to pass inspection?
what is a mechanical fix?
sorry for being such a newb
Old 06-08-2005, 01:34 PM   #8
Panic
Member#: 48699
2008 Evo X GSR
Apex Silver
The search button is your friend
Do this Mechanical fix:
1.Go to Pep Boys, AutoZone, etc and purchase 18mm spark plug anti-foulers.
2. Drill through the end of one the fouler with a 1/2" bit, so that the 02 sensor can clear the hole.
3.Screw back on the other side of the anti-fouler, and screw back in the entire unit into the 02 sensor slot on the bottom of the DP.
If need be combine multiple foulers to get desired effect.
Old 06-08-2005, 03:57 PM   #9
ACLerok
Member#: 27915
2004 Subaru WRX STi
if i bought the gp moto mechanical fix, would it do the trick?
Old 06-09-2005, 12:59 PM   #10
ACLerok
Member#: 27915
2004 Subaru WRX STi
no one knows or has this?
Old 06-09-2005, 01:03 PM   #11
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
I would contact the DMV and/or dealer and get your 4 year exemption. Why are you even messing around w/inspection issues with a nearly new car that should qualify for 4 year exemption?
annointed is offline   Reply With Quote
Old 12-02-2005, 05:26 AM   #12
jadedjeff
Member#: 58069
just passed inspection in NY state with this...
http://www.wrxevolution.com/exhaust.asp
that o2 simulator there
turned off my check engine light, hasn't come back on yet.
and it didn't throw any codes or read not ready on inspection
First time my check engine light has been off in like a year.
I imagine the perrin one would do the exact same thing.
this site helped...
http://mysite.verizon.net/vze7erz1/i...ml#02subaruwrx
gives the wiring for the o2 sensor
jadedjeff is offline   Reply With Quote
The PERRIN™ O2 Simulator me-scooby Vancouver Impreza Club Forum -- VIC 1 01-06-2006 03:09 PM
Perrin O2 Simulator - $60 new... $30 shipped InfamousDX Private 'For Sale' Classifieds 1 04-27-2005 02:43 PM
Perrin O2 simulator Pi7467mp Engine Management & Tuning 2 04-21-2004 11:21 PM
I need help Installing Perrin O2 Simulator chopaholix Texas Impreza Club Forum -- TXIC 6 12-01-2003 09:46 AM
