#1 |
Member#: 84082
Over this weekend I attempted to reset the ECU on my 99 subaru Legacy. During this morning drive to work the idle seems to have gotten worse and the car seemed to almost want to die down and then pick up the rpm. It had one big pulse down but then would even out and smothen. I wonder what the issue might be here.
#2 |
Member#: 82431
NWIC
Vehicle:2006 06 wrx limited CGM |
omg....
There are tons of things that could be going on here. It could be: coolant temperature sensor bad injector Dirty MAF Really dirty air filter bad egr valve/sensor Throttle position sensor. First try to answer the following. Are you throwing a CEL? Does it start hard? Does it do it when warm? Does is accelerate poorly? This is a common and tricky problem. I have learned a lot from this forum. Look around and see what you come up with. |
#3 |
Member#: 5851
VIC
Vehicle:09 Forester XT + NA Miata |
Keep driving it, my guess is it will sort itself out as the ECU is re-learning.
#4 |
Member#: 84082
The Idle has smoothed out but I am having a hard time going up hills now. Today I could not get to 40 mph which I normaly does. I have a persistent CEL and been planning for 2 weeks now to change the oxygen sensor and the knock sensor. I had a code on knock, fuel/air metering and idle sensor malfunction.
#5 |
Member#: 58806
Vehicle:1998 RIP Legacy2.5GT 2.2L legacy wagon |
Im not tryin to steal the thread but im having hesitation while accellerating in 2nd and 3rd gear at like 3500 rpms ... any suggestions( replaced the wires and coilpack )..
thanx main |
| Thread Tools | |
| Display Modes | |
| Bad IDLE, Bad AFR, but no CELL. | CyborgX_CZ | Factory 2.5L Turbo Powertrain | 41 | 03-05-2009 01:19 PM |
| Defective LINK - > Real bad idling | bigbird | Engine Management & Tuning | 31 | 11-13-2002 04:00 PM |
| Bad Idle | wrxvalue | Factory 2.0L Turbo Powertrain | 0 | 07-22-2002 12:19 AM |
| Flutter, whistle, bad idle | RoadRash | Service & Maintenance | 1 | 07-15-2002 04:26 PM |
| So the Vortech SFMU may give me a bad idle... | wcbjr | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 02-22-2002 12:02 AM |
