Old 06-06-2005, 10:26 AM   #1
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
Default I need a gauge to measure intake charge temp
Hi,
I am looking for a gauge that can read the intake charge temp - I would guess with a range around -20 to 200 F...would prefere degrees F. I haven't found anything like this, most of the guages I find for this range are either external temp or water. I need one with a sender that can read the airflow temp the way EGT does.
Any help?
Thanks!
Note: I find that none of the technical forums seems quite appropriate to post so I posted it here becuase I have an STi motor. Maybe engine mgmt?
AntiochCali is offline   Reply With Quote
Old 06-06-2005, 11:12 AM   #2
hwy61
Member#: 87950
2005 STI
Gone....Somewhere in MS
Can't help, but when the Subaru tech was diagnosing problems on my STI his instrument (black box) showed inlet temperature so I'm sure it's possible and might be something that can be simply plumbed into the car's electronics. perhaps the sensor is already there. Hwy 61
hwy61 is offline   Reply With Quote
Old 06-06-2005, 11:16 AM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Delta Dash or a Subaru OBDII reader will show intake charge temp at the MAF sensor.
mbiker97 is offline   Reply With Quote
Old 06-06-2005, 07:10 PM   #4
grovelj
Member#: 88190
Try the coolingmist website. I'd post a link but I don't have enough posts yet. I'm sure you can get it somewhere else, but I haven't seen it anywhere.
Levi
grovelj is offline   Reply With Quote
Old 06-06-2005, 07:20 PM   #5
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
This should go in the electrical forum, but I appreciate your thinking ahead. Search for "Type K thermocouple" here and on google as that might be the ticket.
Old 06-06-2005, 07:24 PM   #6
ranger5oh
Member#: 77752
5Sti 2005 Sti
Any kind of thermometer should work. Note that the Subaru OBDII sensor does read intake charge, and you can log it with most EM systems.. however, it reads it PRE-BOOST. If you want something to read post boost, you will have to plumb it yourself.
ranger5oh is offline   Reply With Quote
Old 06-07-2005, 12:20 PM   #7
seattle944t
Member#: 18308
2005 WRX STi
You need something like this:
http://www.lindseyracing.com/Merchan...NGAUGESINTTEMP
Kingpin (a NASIOC vendor) has a kit like this also, but I can't find it on their web page.
seattle944t is offline   Reply With Quote
Old 06-07-2005, 12:45 PM   #8
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 5MT EJ22T AWIC Swap
cheap solution would be to go get one of those indoor/outdoor electronic thermometers with the lead you run out the window.
You can run the lead under the engine bay and in the intake. However I don't know the range on the thermometer.
Legacy777 is offline   Reply With Quote
Old 06-07-2005, 01:16 PM   #9
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
i dont know about the rexes, but my 04RS has the sensor in the airbox. i know because it was a PITA to modify the cobb cai to still utilize it. so i know it is there. as for the guage if i am not mistaken, a friend of mine has an lcd readout that just plugged in, i think it read that.
doesnt a super afc read that too?
ATX25RS is offline   Reply With Quote
Old 06-07-2005, 05:09 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...I've done this for a LONG time now....had 2 for a while.......and both the gauges that I used(2 different brands----easier to remember which is measuring what ) read to 155°F.....I clipped the probe to the outside of the filter screen on my short ram filter....works great.....maxes out if I sit for a while in traffic.....
Old 06-07-2005, 09:17 PM   #11
GotHP?
Member#: 51138
2004 STi
This is what I did; Radioshack thermometer. Drilled a hole in my IC hose which leads into the intake, inserted the outdoor temp probe, and siliconed it in. It is an awesome tool to have and easy to do. Downside is it does stop reading above 155F...but either way if you're that hot you know it's in heat soak condition. And even so, once you start up and let it idle that cools it down within range quickly.
GotHP? is offline   Reply With Quote
Intake Charge Temp Measurement ltjake22 Water/Methanol Injection, Nitrous & Intercooler Cooling 23 09-29-2012 01:24 PM
Possible to make a gauge to measure torque split of 4EAT? DNut Transmission (AT/MT) & Driveline 10 04-12-2008 01:13 AM
I Need 2 People To Measure Their Dp, Catback ArcAnGeL Newbies & FAQs 18 11-21-2007 01:16 PM
OT: anyone ever installed a fuel cooler to cool intake charge temp? DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 6 03-22-2005 11:42 AM
Intake Charge Temp Gauge stephenmeade Factory 2.0L Turbo Powertrain 1 04-01-2003 08:43 AM
Message Board Statistics All times are GMT -4. The time now is 04:23 AM.
