Old 06-06-2005, 12:38 PM   #1
thedieselspeaks
Member#: 66475
2003 WRX Wagon
Default Help - Headlight goes out w/ new harness
Hello everyone. For about a 1 1/2 years now I've been running an upgraded wiring harness from SUVLights found here: http://www.suvlights.com/wire-harness.htm
The harness is plug n play, as in it plugs into the old harness, and runs new wires to the lights and to the battery. I've paired the harness with some Philips xtravisions from Walmart and it's worked very well.
Recently when I start my car I've noticed that my left headlight will not come on. Sometimes after driving a minute it will come on. What I've been doing is opening the hood and "jiggling" the wires. This seems to correct the lights, but the next time I need them I need to repeat the process.
So, what's wrong with my lights? Are the PIAA relays that are on the harness going bad? Are one of the wires crimped somewhere? Any other ideas? Would it be easier to buy a new harness from them and just say screw it with trying to find the problem?
thedieselspeaks is offline   Reply With Quote
Old 06-06-2005, 01:14 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Have you unplugged the harness and examined the connectors for corrosion? Same for the relays? If none is visible, just plug them back together securely. Sounds like you have a marginal connection, either coming loose or with some corrosion.
Old 06-06-2005, 01:35 PM   #3
thedieselspeaks
Member#: 66475
2003 WRX Wagon
I had considered that but haven't gotten around to checking it yet. Now that I think about it some more that's probably the case (corrosion or something fouling up the connectors). Thanks for the idea; I'll check it out.
Car heats up, one headlight goes out JEEENKINNNS Electrical & Lighting 5 09-28-2007 09:27 AM
HELP! Headlights are out! JackoliciousLegs Electrical & Lighting 3 03-29-2006 10:34 AM
headlight goes out.....but brites still work?? 02 wrx KnightWRX Electrical & Lighting 2 03-12-2006 01:19 AM
Help me pick out my new car!!!!! sem23tex Mid West Subaru Owners Club Forum -- MWSOC 58 05-09-2004 03:23 PM
