Old 06-06-2005, 01:53 PM   #1
GraimeG
Member#: 64865
1993 Impreza L AWD
Default 2.5rs brakes and wheels with 93 Impreza
If I get ahold of some 2.5rs wheels and brakes, will it be relativley easy to swap them onto my 93 Impreza? Would the brakes be worth putting on?
GraimeG is offline   Reply With Quote
Old 06-06-2005, 02:48 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
This is really a question for the brakes forum, but the short answer is yes to the front. The rear is a pretty serious operation that requires hubs, and lateral links to convert from drum to disc. If you do a search in the brakes forum, you will find all the info you need. I've done this conversion a few times and it takes 4-6hours. And you must get the e-brake cables with the rear hubs...
Old 06-06-2005, 03:02 PM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
It is definatly worth it for the front. You will be going from small single piston calipers to a dual piston caliper. You will also be going to a larger diameter and thicker rotor. THe actualy pad size doesn not change. Keep in mind you will not be able to use the 14" L wheels anymore but it sounds like you are getting the 16s from the RS. My L already had the same disc brakes in the rear as an RS because i had the active safety package or whatever you call it. However if you can get the parts, swap out those drums for discs and you will be happier. With some good pads, goodridge lines and the RS brakes My car has a vast improvement over stock (Tires make a difference too).
Hawk296 is offline   Reply With Quote
Old 06-06-2005, 09:33 PM   #4
stickfiguredanny
Member#: 60408
1995 Impreza L
SeaFoam green i think
i just upgraded my fronts to rs brakes there is a huge difference and it was really easy
stickfiguredanny is offline   Reply With Quote
FS Socal: Like New 2.5RS OEM Steering Wheel with Airbag sbrcr267 Interior/Dressup/Audio & Security 4 10-10-2008 12:15 AM
Difference between a 01 2.5rs brake and 02 WRX brake iimiketii Brakes, Steering & Suspension 1 12-29-2004 02:57 AM
FS: 2000 Impreza 2.5RS, Parts and Wheels Schreff Tri-State Area Forum 26 05-10-2004 03:13 PM
2.5RS leather steering wheel with airbag and cruise control Pete Holt Private 'For Sale' Classifieds 10 09-06-2003 11:06 AM
('93-'01) Will 2.5RS eye lids fit a 93 Impreza L-Sedan? Dre2932 Impreza Forum 3 06-04-2001 10:25 PM
