Old 06-06-2005, 03:41 PM   #1
WRX Jim
Member#: 22321
Default anyone spraying nitrous in their 2.5?
anyone?
WRX Jim is offline   Reply With Quote
Old 06-06-2005, 08:52 PM   #2
vteckiller01
Member#: 61516
2005 sti wrb
t67 and a whole lot more!
Not trying to be rude, but if your a scooby specialist shouldn't you know the answer to your own question? But the answer to that question is yes.
vteckiller01 is offline   Reply With Quote
Old 06-06-2005, 08:55 PM   #3
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
I think he's looking for feedback from people who are running it, not wondering literally if anyone does it.
Anyway, Jimmy, if you'll help me pull my motor when it's time for the crawford block, I'll spray mine and we can see what happens
serendipity is offline   Reply With Quote
Old 06-06-2005, 09:50 PM   #4
attitude
Member#: 52043
04 sti
i plan to to spool my t-67, but i haven't really got any feedback about size/type/ etc.
attitude is offline   Reply With Quote
Old 06-06-2005, 11:35 PM   #5
WRX Jim
Member#: 22321
yea i can help pull your motor.. how hard can it be
Old 06-06-2005, 11:35 PM   #6
WRX Jim
Member#: 22321
thanks. I want to know if anyone here is ACTUALLY spraying and what their results have been.
Im not asking a simple question.. CAN YOU SPRAY NITROUS.
Old 06-07-2005, 01:56 AM   #7
jsavage
Member#: 15699
02 wrx
as my buddy always says..."bottles are for babies..."
jsavage is offline   Reply With Quote
Old 06-07-2005, 02:28 AM   #8
gpatmac
Member#: 18446
2002 WRX wagon
psm
Your buddy must be a pretty smart guy.
gpatmac is online now   Reply With Quote
Old 06-07-2005, 03:06 AM   #9
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Jim. I ran a NOS brand import kit on my current 2.5 block. My bottom end is a stock USDM STI block that I got early in 04 which means is the weaker of the 2.5's.
I had typical 50 shot jetting installed since I had a 2.0 before this 2.5 motor. The 50 just did not have the kick it did on the 2.0. Jetting was 22 fuel and 37 nitrous from memory. After messing around with it I called NOS techline and learned a few obvious things. A 50 shot on a 2.0 which on my car produced 50-60whp will not produce that much power on the larger engine. More like 35whp according to what tech support said. I was given new jet sizes for the 50 shot. Which at this time I cannot remember. Those where pretty fun. Then I jetted up to 90shot. I ran it on the dyno with a GT30R based turbo. It produced 90-100whp before the clutch let out around 420whp. I also taxed out the Single walbro pump once the Nitrous came on.
Nitrous is great fun and its cheap. If you take the time to install the kit right and learn how to tune it you will be fine. I would not think about using NOS with out a Good EGT gauge, AFR meter and a Knock link. The knock link is a must. If you hit the button and it dances you know to let out. EGT helps you from melting the motor. lol... It also helps to tune the Fuel jet and lets you know when to let out. Its a duty cycle thing with nitrous. You cant just hold the button down for long periods of time. I left the 90 shot jetting in there on my current GT35R 700hp turbo. I plan on using to to spool up and cut off at 18 psi or so. If I can answer any questions about what kit to get or anything else Email me or call me up.
Clark
Kingpin is offline   Reply With Quote
Old 06-07-2005, 09:12 AM   #10
attitude
Member#: 52043
04 sti
thats exactly what i will need. i'll e-mail you.
Old 06-07-2005, 05:27 PM   #11
chucktoo
Member#: 59539
2005 Outback 2.5 XT
Clark
Please let us know how well the NOS prespool works on the GT-35R .
chucktoo is offline   Reply With Quote
Old 06-07-2005, 05:44 PM   #12
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
sure will. On the 30R it moved everything down 1000 rpm.
Clark
Old 06-07-2005, 06:21 PM   #13
chucktoo
Member#: 59539
2005 Outback 2.5 XT
Sounds great - subscribed.
Old 06-07-2005, 07:31 PM   #14
attitude
Member#: 52043
04 sti
how much would a single wet fogger, like the one you described to me, cost? and where does a wet system input the nitrous?
Old 06-08-2005, 02:18 PM   #15
WRX Jim
Member#: 22321
hmm, so my understanding is..
running a 50 wet shot on a 2.5L isnt quite that effective, im sure it gives some boost of power.
green + nitrous+ race gas, i bet that gives a pretty mean combo.. but then again, no one has done it yet..
Old 06-08-2005, 06:24 PM   #16
chucktoo
Member#: 59539
2005 Outback 2.5 XT
Gt-35R + nitrous + WI with methanol + race gas = soon ?
Old 06-08-2005, 06:54 PM   #17
attitude
Member#: 52043
04 sti
t-67+nitrous+WI/meth+race gas for me
Old 06-08-2005, 07:10 PM   #18
chucktoo
Member#: 59539
2005 Outback 2.5 XT
You mean a turbo like this ?
Old 06-08-2005, 07:21 PM   #19
attitude
Member#: 52043
04 sti
i mean a greddy t-67
Old 06-09-2005, 12:52 PM   #20
vf22STI
Member#: 86847
forget nitrous... it's all about alcohol injection, baby!
vf22STI is offline   Reply With Quote
Old 06-09-2005, 02:09 PM   #21
WRX Jim
Member#: 22321
nitrous> alchol injection as far as power goes.....
Old 06-09-2005, 04:59 PM   #22
STiTuner
Member#: 5778
09 135i
Jet Black
Nitrous Kits are much more reliable than Alcohol injection kits, when setup properly. I can't tell you how many alcohol pumps I've seen fail at the wrong time. Most of the alcohol pumps aren't designed to run alcohol so their bearings and seals go early.
Clark has the right idea, though I preffer the NX brand as the solenoids are built a bit better. Either kits can yield great results!
Nitrous is Cheap and can be controled in so many different fashions, you can customize it to any application. So many people are afraid to use it because they DO NOT KNOW HOW to use it. A Single fogger Wetkit ( or dry depending on EMS) is great to get those laggy turbos flowing, while a direct port provides for great equal distribution to take advantage of a full nitrous assisted motor.
And for those who think bottles are for babies;
Power is Power, doesn't matter where you get it from! There are no excuses for the results at the end of the track!
Brad
STiTuner is offline   Reply With Quote
Old 06-09-2005, 05:31 PM   #23
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
Brad-
do you work for Titan Motorsports?
jam69007 is offline   Reply With Quote
Old 06-09-2005, 06:40 PM   #24
STiTuner
Member#: 5778
09 135i
Jet Black
Originally Posted by jam69007
Brad-
Yes I do
Old 06-09-2005, 11:35 PM   #25
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
do you guys make a TMS Carbon Drive Shaft for an '02+ WRX/STi?
Using Nitrous on an 2.5 RS BKRush North West Impreza Club Forum -- NWIC 28 06-26-2008 02:21 AM
Does anyone have this on their 2.5 RS? STi PWR Interior & Exterior Modification 15 08-07-2003 04:45 PM
Anyone with turbo in their Outback, may be Legacy 2.5? SubaruRules Legacy Forum 6 03-10-2003 02:06 AM
('93-'01) Has anyone swaped a WRX engine in a 2.5 RS? ForeginRacer Impreza Forum 12 08-05-2001 04:39 AM
Anyone done forced induction on their 2.5 GT? byroll01 Legacy Forum 3 08-16-2000 05:23 PM
