Old 06-06-2005, 03:01 PM   #1
wolfemancs
Member#: 82414
Question Fuel Cut or Ignition cut on an STi
Sorry if this question is answered daily like so many are (I tried searching and looking through the engine FAQs), but I've recently started auto-xing, and have realized that sometimes there isn't enough time to bother shifting and it's better to bounce off the rev limiter. I've heard that both fuel cut and ignition cut have their problems (running lean and sending un-burnt fuel throught the turbo/exhaust respectivley). I'm wondering if anyone knows for sure which it is?
C/N: If you KNOW (not just are pretty sure) if the STi has a fuel cut or ignition cut as a rev limiter please reply with answer.
Thanks everyone
wolfemancs is offline   Reply With Quote
Old 06-06-2005, 03:52 PM   #2
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
Fuel cut. The ECU shuts off the fuel pump and injectors. In addition, on the STi, the ECU controls the drive by wire throttle and closes the plate.
serendipity is offline   Reply With Quote
Old 06-06-2005, 03:53 PM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Fuel cut
ECU cuts fuel by tuning off the injectors, then it turns off the fuel pump, then it closes the throttle
mick_the_ginge is offline   Reply With Quote
Old 06-06-2005, 03:57 PM   #4
CMJ
Member#: 39235
You should use fuel cut unless you are running n2o. Ign. cut has caused valve train damage to some posters in the past.
CMJ is offline   Reply With Quote
Old 06-06-2005, 04:00 PM   #5
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Sorry, is the question : What does the stock ECU do? Or is it which to use?
We have answered: What does the stock ECU do?
As for "which to use?" then what CMJ said, the only issue is that I think you are running a UTEC which does not have this feature for the STI yet.
Old 06-06-2005, 04:34 PM   #6
wolfemancs
Member#: 82414
Cool. That's what I was looking for (what the stock ECU does). As a follow-up, is there any real harm coming from bouncing off the rev limiter? I have a friend who's been around turboed/supercharged mustangs and they've had problems with fuel cut blowing head gaskets, so that's why I'm curious.
Thanks for all the help guys,
Craig
Old 06-06-2005, 06:24 PM   #7
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
fuel cut, i had it in my sti when i had a full turboback with out any engine mangment i peaked at 22 psi and the car just died on the freeway. but now its tuned
WRXout is offline   Reply With Quote
Meth + Launch control... Fuel or ignition cut?? rpeirats Water/Methanol Injection, Nitrous & Intercooler Cooling 1 04-05-2009 11:05 AM
Rev limiter: Fuel cut or spark cut? Marion Cobretti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-25-2005 04:35 PM
Anyone with Espelir GT's on an STI have to cut the bump stops roybfr Brakes, Steering & Suspension 3 12-27-2004 02:12 PM
Anyone dyno or 1/4 mile an 18g on an sti yet? odin1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 10-24-2004 02:02 AM
Is the AP safe to run with stock injectors and fuel pump on an STi? Irishman Engine Management & Tuning 5 08-30-2004 01:10 AM
