Old 06-06-2005, 07:32 PM   #1
cd3575
Member#: 5456
2001 RS
Default Is it dead?
Ok here is my situation. I am prepared for the worst (new motor).
Driving today normal speeds I start to hear a faint knock, turn down radio listen to try to figure where it was coming from. Well it got louder and definitly from the engine and then engine started to die/ sputter. Pulled off called a flat bed. Home full oil no check engine light. Loud as all hell coming from drivers side head definitly. So I pull the plugs. #2 plug is BLACK!!!!! carbon on wire the whole plug, OH and the electrode and the tip of the plug are gone! Next step replace all 4 plugs and wires use probe magnet to pull anything from #2. Just pulled a ton of carbon deposit. Put it all back to gether and i am still knocking.
So any ideas? Bent valve bottom end shot, etc. What is a new motor with install? Any used ones out there?
Oh I have a 2001 RS with 90,000 on it.
cd3575 is offline   Reply With Quote
Old 06-06-2005, 07:44 PM   #2
kpalena
Member#: 82431
2006 06 wrx limited
CGM
Sounds like the plug electrode came off and hurt the exhaust valve. Get her to a mechanic. I do not think a new engine is in order though. Tear the top end apart, I think you will find the problem.
kpalena is offline   Reply With Quote
Old 06-06-2005, 07:45 PM   #3
Hayes
Member#: 11808
Could very well be a broken timing belt or jumped belt. That would mean a major top end rebuild.
Hayes is offline   Reply With Quote
Old 06-06-2005, 07:52 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I'd Like to see the results of a compression test.
How long has it been since you changed plugs?
You should also check your oil pressure with a mechanical guage.
You said you put it all back together, did you re-use that crappy plug?
Fingers crossed for you.
Tim Sanderson is offline   Reply With Quote
Old 06-06-2005, 08:31 PM   #5
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
Sound like a great time to consider an 02 WRX motor swap ....
imprezzakc is offline   Reply With Quote
Old 06-06-2005, 09:51 PM   #6
cd3575
Member#: 5456
2001 RS
would love to WRX swap but the best part is I am betwee jobs at the moment and this really does not help.
If some one can help with posting the picture i snapped one of the plug, and sure did not re use it replaced all 4 wires and plugs been about 18 months since did all of them last by the way. Oil is fine checked dip stick and have an oil gauge on the pillar. Bottom is also dry as a bone.
Car when it runs now sounds like a rattle can, but still also sounds good you know the exhaust note is still there and all. Also pops right off.
Enginuity is it dead? zman519 Engine Management & Tuning 2 09-22-2007 07:29 PM
Damn this cat is a heavy sleeper....or is it dead? You decide HotAirSti Off-Topic 13 08-24-2006 11:24 PM
Is it dead? cd3575 Mid West Subaru Owners Club Forum -- MWSOC 10 06-12-2005 05:40 PM
Autometer oil pressure gauge...is it dead? Turbo9000 Electrical & Lighting 5 12-02-2003 07:36 PM
P1 Lip replica, is it dead? Arnie Interior & Exterior Modification 2 07-29-2001 07:33 PM
