Old 06-06-2005, 08:20 PM   #1
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Default Defi bf gauges installed with technical problems
My Defi Bf gauges was installed today (Boost, EGT, Oil pressure). I used the oil gallery plug for the oil pressure gauge. The EGT was tapped at the collector.
Now the problem starts, first my cruise light started to flash. I went through a car wash and when I started the engine it was gone. Later on the drive it came back on. I would think that when itís cold it will go away. Then my check engine light is on. I checked the oil level and it was fine. Then while outside I noticed that my park light is also on.
Can anyone give me advise on where to check first. My car is an 05 STi.
ix8vii is offline   Reply With Quote
Old 06-06-2005, 09:44 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The parking light being on is this-
http://forums.nasioc.com/forums/showthread.php?t=502948
As for the check engine light and flashing cruise light, this means that a trouble code has been stored in the ECU. Go to Autozone and get the code read (they do it free), or find someone local to you with a scanner. Once you have the numerical code post it here and we can better figure out what the problem is. You apparently messed something up while doing the gauge install and the code may help to find out what it is. In the meantime you can check under the hood for any disconnected wires or hoses.
And BTW this would not have anything to do with oil level, low oil will not trigger a CEL or any other warning from the ECU as there is no oil level monitor aside from the plain old dipstick.
Old 06-06-2005, 10:44 PM   #3
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
I knew that parking light switch
I'll check the code tomorrow. Thanks a lot. Now I got the gauges installed. I still don't know what the readings should be for stock. Next move will be to open the manual to avoid another embarrassment issue like the parking light switch
Old 06-07-2005, 07:02 PM   #4
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Code 1153
It started with a flashing cruise light until I drive for a while or w00t then the check engine light will come on. My car is completely stock. I was thinking of loading my Accessport to see if it's going to fix code.
Where do I begin
Old 06-09-2005, 02:40 PM   #5
subieworx
Member#: 47769
P1153
H02S Insufficient Switching Bank 2 Sensor 1
No idea what that means. I would assume it has something to do with what wires you tapped for the gauges install. Can you walk us through exactly where you tapped?
subieworx is offline   Reply With Quote
Old 06-14-2005, 12:39 AM   #6
Impreza4ever
Member#: 62510
2005 Impreza Wrx Sti
WR BLUE PEARL
Actually the P1153 is for 02 sensor performance high meaning the ecm is not seeing the o2 sensor switching for some reason. Now i dont think there was a reasson for u to tapped on the 02 sensor wiring. Now Sti's use what is called a lambda sensor so when the ecm sees a value >1 means lean and <1 means rich different from o2 sensors when over 450mv means rich and bellow 450mv means lean. What i think is that u left a vacuum hose unplugged while u were installing the boost gauge or maybe u have a leak at the EGT probe , that would cause a lean reading for the sensor due to the ammount of extra oxygen in the exhaust stream. Let me know what did u find.
Good luck
Impreza4ever is offline   Reply With Quote
Old 06-14-2005, 02:27 AM   #7
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Impreza4ever actually the dealer found that the clip was pinching the o2 sensor wiring. we'll see what happens if it comes back after the part was change. i'll keep you posted.
Old 06-15-2005, 03:20 PM   #8
Impreza4ever
Member#: 62510
WR BLUE PEARL
What clip?
WTT: My Defi BF gauges for your Non BF gauges rob Interior/Dressup/Audio & Security 5 01-07-2007 05:51 PM
Do all connectors for Defi Link gauges work with Defi BF gauges? mav1c Electrical & Lighting 0 11-13-2006 02:38 PM
ABS light after Defi BF gauge install - Help! Cleveralias Electrical & Lighting 0 12-13-2005 07:50 PM
DEFI BF Gauges - Impressions/Installs Weakness Electrical & Lighting 1 11-21-2005 07:17 PM
Atlanta Defi BF Gauge install prices jtslade Interior & Exterior Modification 3 03-16-2004 01:27 PM
