Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 06-07-2005, 12:56 AM   #1
kx02wr
Member#: 59112
02 wrx
Default Noob ? about loading maps on UTEC
Does the ecu have to be installed to the UTEC for it to load base maps? Isn't that why they give u the 9v battery. I just read a thread on wrxhackers and this dude said it has to be hooked to ecu. guy i bought utec off had all tuned stage 4 and up maps and my car is totally stock so def don't wanna put it in my car with these maps. help thanx
kx02wr is offline   Reply With Quote
Old 06-07-2005, 01:06 AM   #2
Neek
Member#: 3400
2013 Gojira
2007 Triumph Speed Triple
you can use the battery and hook it up to your desktop to remove the maps. It does not need to be connected to the ECU.
In the future you may want to put these topics in the Engine Management forum.
Neek is offline   Reply With Quote
Old 06-07-2005, 01:12 AM   #3
kx02wr
Member#: 59112
02 wrx
Yeah i was thinking of posting there but such a stupid question I figured this might be a better place. So u say it can be hooked up 9v to remove old maps, but what about loading new ones? Also where can i get info on removing the old maps. I was under impression could just load new map over the old one and be done with it. I really need to read txs manual couple dozen more times
Old 06-07-2005, 01:15 AM   #4
Neek
Member#: 3400
2013 Gojira
Yes that's what I meant. You can download the stage 1 map from TXS (for a stock car), put it in slot 1 and start from there.
Old 06-07-2005, 01:21 AM   #5
kx02wr
Member#: 59112
02 wrx
thanx
Old 06-07-2005, 03:56 AM   #6
Uncle Scotty
Visiting NASIOC Timeout
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....w0w.....knew it without even having to be told....
....d00d......do you have a laptop???? If not, you will need one(or a compatible pda or some such) for your UTEC..........if you have a laptop, you just use the serial cable, or any serial cable to connect to the laptop----which has the map ya want on it-----and in a minute, map loaded-----with the UTEC in the car.....the 9v battery thingie is to keep the UTEC powered while you load/change maps with it not connected to the car(the car's electrical system must be 'on' when altering the UTEC's parameters).
You may want to save that stage 4 map to look at in the future......just put the map ya need in another slot in the UTEC.....and keep reading
Old 06-08-2005, 12:19 AM   #7
kx02wr
Member#: 59112
02 wrx
U scotty u are the man. I thought i could hook the utec up to my comp in my house and load the maps but now i know better. At the
moment i don't have a laptop but it's in the works. My friend has a laptop and is way better at computer stuff than me so when i put the utec in hopefully all will go smoothly.
Old 06-08-2005, 12:28 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
....you CAN hook up the UTEC to the desktop computer and use the 9v battery to power the UTEC so that the UTEC can be manipulated.....a laptop is just far easier to use a laptop.
Old 06-08-2005, 03:17 AM   #9
GreekPrincess
Member#: 88773
going to try new 9v and hopefully all works out
GreekPrincess is offline   Reply With Quote
loading maps onto utec? wrxracer87 UTEC 5 09-07-2006 01:52 PM
can't load map on accessport, help chibich AccessPort 3 07-03-2006 10:56 PM
HR: Help!! anyone with a laptop to get stg3 map on utec boost4life Mid Atlantic Impreza Club -- MAIC 3 04-11-2005 09:11 PM
trouble w/loading map to utec mcu81 Engine Management & Tuning 3 04-05-2004 03:49 PM
knock w/ stage 4 map on UTEC? WRteXmeX Engine Management & Tuning 6 03-22-2003 11:14 AM
