Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 06-07-2005, 11:43 AM   #1
RockRaceScooby
Member#: 57120
1999 Forester
Red
Default Coolant Flow EJ25
So, the EJ25 from my '99 Forester, the water pump pulls from the top of the block and pushes it out the bottom? Seems backwards, buit the thermostat is on the bottom, so I can't figure out how else it could work. Just curious...
RockRaceScooby is offline   Reply With Quote
Old 06-07-2005, 01:40 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
You have it backwards.
This scan is for the first gen legacies, but the flow setup is the same
http://www.main.experiencetherave.co...ng_diagram.pdf
Legacy777 is offline   Reply With Quote
Old 06-07-2005, 03:30 PM   #3
RockRaceScooby
Member#: 57120
1999 Forester
Red
So, that would mean the thermostat goes in spring up. I think I put it in that way.
Old 06-07-2005, 07:15 PM   #4
Legacy777
Member#: 4800
Correct, spring up. It will only fit in that way. This is assuming you replaced it with an OEM part. I will say that if you didn't, you're going to have weird engine temp issues, and that I highly recommend you go back and put in an OEM thermostat.
Old 06-07-2005, 09:32 PM   #5
RockRaceScooby
Member#: 57120
1999 Forester
Red
I had a couple instances where it all of the sudden got hot like I had an air pocket or something. That is why I was wondering.
Old 06-07-2005, 09:40 PM   #6
RockRaceScooby
Member#: 57120
1999 Forester
Red
I did replace the thermostat, but I used the "better" OEM one from the parts store. Nothing special.
Old 06-08-2005, 11:02 AM   #7
Hayes
Member#: 11808
Many after market stats that fit do not have a large enought ventura opening and will cause overheating during high loads.
Hayes is offline   Reply With Quote
Old 06-08-2005, 01:24 PM   #8
Legacy777
Member#: 4800
replace it with a subaru thermostat.
Do you remember if the two t-stats looked identical?
Overheating....No Coolant Flowing Through Radiator wrx110487 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-28-2008 01:51 AM
coolant flow diagram johnkaldar Subaru Conversions 5 08-22-2007 06:33 PM
Lose the Coolant flow through the Throttle body? Crazyhippy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-10-2006 08:33 PM
sound of coolant flowing in engine niftybee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-17-2003 09:23 AM
coolant flowing through throttle body LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 20 11-07-2001 10:27 AM
