Old 06-07-2005, 08:49 PM   #1
Doob
Member#: 72493
97 outback sport
red
Default Whining noise under load
Hey guys,
I just noticed today on the drive home that my cars driveline is making an unusual whining noise under load.
(yes I did a search, i didn't come up with anything that accurately described my problem)
I haven't had a chance to investigate as much as I'd like, but what i've determined so far is that between 3900 and about 5600 RPM I hear a new whining noise, (I think) from behind me. The noise only occurs under acceleration, if I lift my foot off the throttle it dissappears. It only occurs when the car is in gear, and so far I've only been able to confirm it's existence in 1st and 2nd gear (more testing in 3rd and 4th tomorrow hopefully).
The noise gets a little bit louder, and a little bit higher pitched as the revs rise.
Any ideas as to what it could be?
I spoke breifly with a local subaru dealer and they theorized it might be the awd transfer case bearing.
Also, I'm very interested to hear if that problem (or if what you think the problem is) could be as a result of improper towing. My car was towed yesterday and i don't recall hearing this noise before that. I was told that it was towed with the rear wheels on dollies so there SHOULDN'T have been any damage. That, of course, is assuming they told me the truth.
Finally, if it's the transfer case bearing, anyone have theories as to how much it might cost have it repaired/replaced? Likewise, if you think there's a different problem, I'd like to hear how much it could cost me. Also, is this a serious problem? Does it need to be addressed now before some kind of catastrphic failure, or is this the kind of problem that ought to be more or less benign?
Thanks for your time and expertise,
Doob
Doob is offline   Reply With Quote
Old 06-07-2005, 09:12 PM   #2
Doob
Member#: 72493
97 outback sport
red
updates and corrections
First of all, the whining/whistling/high pitched noise doesn't occur all the time between 3900 & 5500 when in gear, I must be at or near WOT.
Second of all, I was mistaken, the noise does occur when in neutral, and when the clutch is depressed (I obviously wasn't putting it to WOT under those condiions before).
I tested in 3rd gear (need to get out of the city to test 4th gear, at 3900+ with WOT), and it didn't seem to occur in 3rd.
I'm also uncertain as to where this sound is coming from, I thought it was coming from behind before, but now I'm not so sure.
So, given this new information, my new theory is this could be drivetrain, exhaust, or something to do with the engine... I have infact only made things more ambiguous as a result of further testing =/ but at least now the information is more accurate...
Old 06-08-2005, 11:58 AM   #3
Doob
Member#: 72493
97 outback sport
red
Could a mod please move this thread to naturally asperated?
My new leading theories are engine/exhaust...
Old 06-15-2005, 01:32 PM   #4
Doob
Member#: 72493
97 outback sport
red
bump
any ideas guys?
Old 06-15-2005, 05:51 PM   #5
mrpedal
Member#: 71361
2000 Impreza 2.5RS
Any chance you got a CAI on that? That's almost exactly the rpm range where mine starts screaming (Just a Ganzflow tube mod on mine). I mention this also because I noticed it more when I didn't have it securely on after a fliter cleaning, and the whine went away after tightening things back up. Just a guess. Maybe you can tell us more about recent maintence to your car (or lack there of, if that's more pertinent )
mrpedal is offline   Reply With Quote
Old 06-15-2005, 10:47 PM   #6
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
Tranny bearing. Happened to me. It will get louder and louder as the bearing gets worse. Then it seizes. Then you're in trouble.
Our AWD cars should only be towed on a flat bed.
CitySubie is offline   Reply With Quote
Old 06-16-2005, 12:37 AM   #7
Doob
Member#: 72493
97 outback sport
red
you think tranny even though the noise occurs in neutral and with the clutch in?
As for CAI, nope, but I do have a K&N, it hasn't been touched since it was installed (about 4500km ago). I was planning to go in for my 96k service in another 1000km, I'm not sure if this should wait though. I'll check the intake and see if that's it, hopefully that's all it is.
Old 06-16-2005, 01:53 AM   #8
darkwaterz
Member#: 65165
97 OBS
i miss my RS...
There's a similar problem described in the technical/mantainance forum... the consensus seems to be a leak in the exhaust system, do a search for "high pitched squeal" in that forum for more lengthy details.
z.
darkwaterz is offline   Reply With Quote
Old 06-16-2005, 07:50 AM   #9
Rioken
Member#: 80263
my car did the same thing, went away after I put the exhaust on it
Rioken is offline   Reply With Quote
Old 06-16-2005, 01:25 PM   #10
Doob
Member#: 72493
97 outback sport
red
I'm leaning towards exhaust too, cause over the past week, it seems to have become a bit raspier under engine braking, and maybe even a little bit of rattle (again, under engine breaking).
So, if it's exhaust, do you figure it's a fault of some sort? or more likely just some loose bolts?
Hopefully I can take a closer look this weekend when I have more time.
Old 06-17-2005, 07:17 AM   #11
Sober_One
Member#: 83322
2000 Impreza 2.5RS
Sylverthorn
You may have good ears and be detecting the initial signs of wheel bearing failure. Wheel bearings have been known emit some weird whining noises during their failure.
Just another thought.
Sober_One is offline   Reply With Quote
Old 06-17-2005, 04:29 PM   #12
Doob
Member#: 72493
97 outback sport
red
But wouldn't wheel bearing noise be related to speed and not rpm?
Old 06-17-2005, 06:48 PM   #13
wht052.5
Member#: 79527
2005 2.5RS(I NDTRBO)
Chipped Crystal Gray
Rear diff?
wht052.5 is offline   Reply With Quote
Old 06-18-2005, 12:05 AM   #14
Sober_One
Member#: 83322
2000 Impreza 2.5RS
Sylverthorn
I thought that if the noise only happens when the car is rolling, than it may be a wheel bearing.
Maybe I misunderstood the part about being in neutral and the clutch
Old 06-18-2005, 03:31 PM   #15
Doob
Member#: 72493
97 outback sport
red
In my first post I said it didn't happen at a stand still in neutral/with the clutch in, but in my second post I corrected myself. Apparently the noise only happens in those rev ranges when at or near WOT, which I wasn't trying at first (a little hesitant to go WOT in neutral).
As for rear diff, I had thought of that too, but figured it should be more of a grinding/clunking noise than a whistle/whine, correct? Also, I would expect a rear diff to be more consistent in it's noise generation.
Old 06-19-2005, 08:47 AM   #16
tmeh
Member#: 30800
2000 .7 RS
if its exhaust its easy to check theres only a few places it'd leak, and if your car is all original it's probably the graphite donut section after the cat... it will deteriorate over time.
you can wrap tin foil around the sections with gaskets to see if any black builds up on it, or if its a really bad leak it'll burn a hole in the tin foil
but chances are if you can pick off sections of that flex donut thats your problem
and a worn pinion in the rear dif will make a whine, but its a totally differnt sound from an exhaust leak, resonates through the whole car (depending on your level of bushing/mount mods)
tmeh is offline   Reply With Quote
Old 06-20-2005, 04:31 PM   #17
Doob
Member#: 72493
97 outback sport
red
We took a closer look yesterday and it seemed to be loudest near the front of the car, possibly around the first cat there, which corresponds to your theory nicely.
We were worried it might be the cat, but you think it's possible it's just the graphite donut? That sounds less expensive than a new cat, am I correct in that assumption?
Finally, am I doing any damage by not addressing a potential exhaust leak early on? I suspect the only problems would be sound levels and maybe exposure to exhaust gasses when idling.
The reason I ask is I just bought a house and I really don't have the cash to take care of this right now...
Old 06-20-2005, 06:46 PM   #18
tmeh
Member#: 30800
2000 .7 RS
good custom exhaust shops will only charge you around $30-50 to change that donut. you can do it yourself, you just need the donut and some red exhaust gasket maker, plus maybe some help compressing the springs when you put the pipe back together.
exhaust leaks affect performance, somewhat. more irritating than anything, really.
Old 06-20-2005, 07:49 PM   #19
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
If you have a mega hardcore leak up at the exhaust flange, you can burn up your valves, but it sounds like you're far away from that.
I had something that would fit your description, but it turned out to be a Throwout Bearing that had not been lubed (or had lost all it's lube). Made a noise like air hissing except for when I put the clutch in, even while rolling in 4th gear or stopped.
mranlet is offline   Reply With Quote
Strange noise under load quadtard Transmission (AT/MT) & Driveline 9 12-18-2007 07:14 PM
MT Noise under load RobJ Transmission (AT/MT) & Driveline 0 11-15-2007 12:49 AM
installed teins...noise under load...normal? fireantresq Brakes, Steering & Suspension 3 05-31-2006 11:27 AM
Feint Noise under load / acceleration rukkie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-23-2005 07:49 PM
help me diagnose a weird noise under load Capt Crunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-17-2004 07:42 PM
