Old 06-08-2005, 08:38 AM   #1
avengermike
Member#: 88713
04 STi
Default a'pexi turbo timer-air/fuel read out hook up?
okay was reading the last post and it said it was in the wrong place so not to sure if this is right any how, i bought the a'pexi slim turbo time and it has a air fuel read out can anyone help with this what wire do i tap into?
i have a 04 sti
avengermike is offline   Reply With Quote
Old 06-10-2005, 04:08 PM   #2
gbearz
Member#: 82881
I think ravensblade has the diagram for the wireharness for the ECU.
gbearz is offline   Reply With Quote
Old 06-11-2005, 09:59 PM   #3
avengermike
Member#: 88713
04 STi
i have the diagram but where is the ECU someone said behind the pass kick panel but no luck
Old 06-11-2005, 10:06 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The ECU is under the passenger footwell. Peel back the carpet, you'll see the metal cover that's over it. Remove that and the ECU is underneath. Disconnect the battery before unplugging the connector and messing with the wiring.
Also note that the TT will only be able to tap into the rear 02, same as the cheap A/F gauges, so it won't be getting accurate readings.
Old 06-11-2005, 10:09 PM   #5
avengermike
Member#: 88713
04 STi
cool i get my pod soon putting a boost gauge i can read and pyro meter in
Old 06-12-2005, 06:30 PM   #6
avengermike
Member#: 88713
04 STi
i have the wire diagram for an 02 wrx but not matching my ecu plugs. i have a 04 sti
Old 06-12-2005, 06:50 PM   #7
avengermike
Member#: 88713
04 STi
okay found the o4 diagram but is says that their is a rear oxygen sensor and a rear oxygen sensor heater signal which one do i use? the dif is on says ign sw on (eng off) the siganl says 0, and the hearter signal is 0-1.0, the other box says eng on (idling) the signal says 0-0.9 and the heater signal has no read out?
sorry because i dont have more then 10 post i cant post the url
Old 06-12-2005, 07:25 PM   #8
avengermike
Member#: 88713
04 STi
this thing is not going well im lookin at the diagram i have and my plugs dont look like any on this diagram, how can u tell what plug is what and what pin is what?
A'PEXi turbo timer NIB blazeEJ20 Interior/Dressup/Audio & Security 0 09-19-2007 09:55 AM
a'pexi turbo timer and up-pipe VFwrXrated34 Engine/Power/Exhaust 1 02-11-2007 11:05 AM
A'PEXi Turbo Timer for sale - San Diego YinUCSD Private 'For Sale' Classifieds 10 02-02-2004 02:46 PM
A'PEXi Turbo Timer and A/F meter jfalcon001 New England Impreza Club Forum -- NESIC 0 09-17-2002 04:30 PM
A'pexi Turbo Timer installed (pics) wrx2fast Member's Car Gallery 18 07-20-2002 07:12 PM
