Old 06-08-2005, 09:25 AM   #1
Vlad
Member#: 46135
02 WRX
Powered by Sti V9 Spec C
Default 04-05 Sti rear suspension to 02 WRX
I want to confirm some info:
My early '02 WRX might have a bit bigger diameter rear sway bar than a '04 Sti? 20mm vs 19?
If the '05 rsb were to be desirable to me (it isn't as it's 20 as well, no?), would it mount right up?
How about the Sti endlinks? if I were to use a bracket such as the Poltec bracket (I know they don't sell it separately), would I be able to use Sti endlinks?
How about the lateral links and trailing arms? Does the Sti come with nothing but spherical bearings everywhere? Whould any/all fit, or maybe only the '04?
I realize that the links will not have the ears for the endlinks and would use bracket based endlinks
How about the front sway bar and endlinks? is it any beefier than the 02 WRX?
How about the aluminum a-arms? do they come with a spherical bearing bushing where they mount to chassis?
Also, can anybody confirm that the USDM sti complete struts only drop the wrx less than an inch all around? And is the ride very harsh because of the spring rates?
A lot of questions, I know, but I could really find only little info when I looked.
Thank you,
Vlad
04-05 sti hood scoop to 2002 wrx scoop wrxkid157 Interior & Exterior Modification 9 01-16-2012 09:58 PM
04/05 STi Bumper on a regular WRX? Gizmo45 Interior & Exterior Modification 22 07-28-2010 09:21 PM
How to fit 04-05 STi Rear Brembos to my 02 Bugeye Wagon? PICS ---> iGotWood Brakes, Steering & Suspension 1 02-24-2008 03:14 PM
04-05 STi interior into an 02 WRX? designfate Interior & Exterior Modification 6 11-14-2006 03:10 PM
SoCal: 04-05 sti splitters $70 & 02-04 stock wrx wheels $100! poogiboy SCIC Private Classifieds 8 08-24-2006 11:02 PM
Message Board Statistics All times are GMT -4. The time now is 02:28 AM.
