Old 06-08-2005, 01:22 PM   #1
abosworth
Member#: 53856
2012 Speed3
Red Mica
Default Trouble with '92 legacy 2.2L N.A.
I have searched on this subject and have found a few things but maybe someone can help me or tell me where to look.
I have a 92 lecacy 2.2L non turbo and it runs well except lately it has been starting kind of hard when its warm out. It always starts right up with ease in the morning before i go to work. Then I get to work, park it for 3 or 4 hours. when I try to start it after it has been sitting in the sun for that time it is harder to start. I can always get it to start eventually but i just want to fix it so i don't have this problem. Sometimes when i finally do get it started it runs really crappy almost like not all of the cylinders are working. when this happens i just shut it off and start it again and it is fine. I am at a loss as to what is wrong with it as i have replaced the obvious things that i could think of. Here is what i have replaced.
Spark plugs/wires
ignition coil
cts (coolant temp. sensor)
O2 sensor
fuel pump
If anyone has any ideas i would much appreciate it
thanks,
abosworth is offline   Reply With Quote
Old 06-08-2005, 05:44 PM   #2
pieces
Member#: 42964
08 STI, 03OBS, 99L
I wish I could help. I had a similar problem with my 99L (also 2.2L).
Mine went away with new plugs (I think at least). It only happened like 2x per year and only when it was cool in the morning and blazing hot in the afternoon.
pieces is offline   Reply With Quote
Old 06-08-2005, 06:03 PM   #3
ringe
Member#: 49998
2007 WRX CT Stg 2
Fuel pressure regulator may be crapped out; if it lets pressure leak out of the lines it won't start as well, because, well, it won't have as much fuel to work with. The fact that you can stop it and restart and it works just fine seems to support that, because at that point the system was come up to full pressure, but I could be wrong.
ringe is offline   Reply With Quote
Old 06-08-2005, 06:47 PM   #4
abosworth
Member#: 53856
2012 Speed3
Red Mica
That is what i wanted to hear. The fuel pressure regulator was my next guess. i checked it out and there is no leakage or anything. i was also thinking it might be the air pressure sensor. i think i will try the fpr and see if that works. i will post how it turns out.
thanks again,
adam
Old 06-09-2005, 12:43 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Does the engine run any worse or better once it's reached normal operating temp....compared to when you just start it up...either in the morning or afternoon?
Legacy777 is offline   Reply With Quote
Old 06-09-2005, 12:49 PM   #6
abosworth
Member#: 53856
2012 Speed3
Red Mica
It is usually fine once it gets up to normal op temp. Last night I did a self diagnostic test and figured out that the purge control solenoid was defective. I am going to replace that and see if that might be it. I will post the results.
Old 06-13-2005, 10:31 AM   #7
abosworth
Member#: 53856
2012 Speed3
Red Mica
After pulling the check engine code from my ecu i got a code 35 which is a faulty purge control valve solenoid. I replaced that on friday and the car seems to be starting easier. it did start kind of hard once this weekend but not nearly as much as it normally does. I still suspect that the fuel pressure regulator is shot but from what i have read it seems like your car will barley run if the fpr is dead. I checked the price for one and it was $144 at nappa so i think i will wait on that. haven't had a check engine code at all eigher since i fixed the purge control valve.
Old 06-13-2005, 08:47 PM   #8
Legacy777
Member#: 4800
If the purge solenoid fails open, it can cause issues with starting and idling especially.
If your fpr fails, ie the diaphragm isn't doing anything, you'll just have a higher fuel pressure at idle, and will run richer then you should. That shouldn't cause a hard start situation....infact the fpr really doesn't play any role in fuel pressure regulation until the car is running. So I wouldn't worry about the fpr.
Another thing you might want to do is reset the ECU. Pull fuse 14 EGI/TCU fuse for 20 minutes or so.
Old 06-14-2005, 10:26 AM   #9
abosworth
Member#: 53856
2012 Speed3
Red Mica
Another thing you might want to do is reset the ECU. Pull fuse 14 EGI/TCU fuse for 20 minutes or so.[/quote]
Doesn't pulling the negative batery cable acheive the same purpose? I just pulled the fuse anyway like you said but there were no codes left after i pulled the negative batery cable.
Old 06-14-2005, 12:28 PM   #10
Legacy777
Member#: 4800
Yes, pulling the neg battery cable will do the same thing. Personally I think the fuse is easier....just me I guess.
90 legacy 2.2l swap with 2000 wrx 2.5 turbo HairySheep Subaru Conversions 10 03-03-2006 07:03 PM
early 90's Legacy 2.2L Turbo motor into a 1993 L? quentinberg007 Subaru Conversions 6 07-07-2003 06:22 PM
('93-'01) Legacy 2.2L/Impreza2.2L? adam555 Impreza Forum 2 09-25-2002 06:15 PM
WTB or trade plus cash...91-94 Legacy 2.2L turbo 5 speed Aspen_2.5RS South East Region Forum 23 07-10-2002 06:18 PM
Looking for info/pics of Legacy 2.2L turbo motor jakeslick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-18-2001 11:02 AM
