Old 06-08-2005, 10:45 PM   #1
klie5111
Member#: 79895
2002 WRX Wagon
Default Gauge wiring --in process--HELP
Removing the stock boost gauge and wiring in greddy egt and boost. There are three power wires for the greddy; acc, power, lighting, and only one for the stock. Can i connect all three of the greddy power lines together and run them to the stock power?? The stock power is spliced somewhere in behind the radio...does the stock one get split out behind the scenes with a different input for acc, lighting, etc?
klie5111 is offline   Reply With Quote
Old 06-09-2005, 12:13 AM   #2
klie5111
Member#: 79895
2002 WRX Wagon
Bump for someone still working on the project.
Old 06-10-2005, 12:46 AM   #3
scuBdoB17
Member#: 63650
1997 Impreza 2.2L
Green
To answer your question. Yeah, you can connect all three wires to the source. By doing that you are putting all three of those wires in parallel which means they will all be getting the source voltage. If you dont understand that you can look at it this way. When you are putting up christmas lights notice how when you plug one strand into another the lights get dimmer down the line. (That is considered putting them in SERIES.) If you plug each strand of lights in a different outlet, then they all get the same amount of voltage. (That is considered PARALLEL.) Hope that helps you.
scuBdoB17 is offline   Reply With Quote
Old 06-10-2005, 01:38 PM   #4
gh32
Member#: 9594
2005 WRX
Yep. What he said. ^^^
My question is, how come you're not wiring them fully? It takes a bit of work to find all the pieces, sure, but it's worth it in the end I feel. Plus, if you only need 12V, Accessory, and Illumination, you can find them all behind the stereo.
-George
gh32 is offline   Reply With Quote
Old 06-11-2005, 06:13 PM   #5
NorCal11.7
Member#: 55879
2000 Impreza 2.5 rst
Blue Ridge Pearl
YOUD WOULDNT HAVE ANY OF THE GREDDY WIRING DIAGRAMS STILL WOULD YA? IM HAVING TROUBLE WITH MINE STILL
NorCal11.7 is offline   Reply With Quote
HELP wiring in Gauges. Marlons101 Alaskan Impreza Club Forum -- AKIC 34 03-14-2009 04:40 PM
HELP! trick to last downpipe bolt? in process need help! Blue Rabbit 02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-29-2005 06:08 PM
Help what wires on the clock do I tap for gauge wiring BIG BEN Electrical & Lighting 2 11-09-2002 01:04 PM
gauge wiring clock wire ? help dark knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-14-2002 07:26 PM
