Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 06-09-2005, 09:54 AM   #1
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Default What's the deal with the B4 Engine?
I've heard so many different things about it, and I want to know FACTS. Can it, or can it not fit in our cars? I heard yes, but you have to custom fabricate the downpipe and a few other things. Does someone have a no BS answer that they're sure of?
/Jonathan
Teh Legacy is offline   Reply With Quote
Old 06-09-2005, 11:49 AM   #2
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
From what I hear the biggest issue is going from RHD to LHD. I think for the price its easier to swap in a WRX motor that came from a LHD.
But I really have no idea what I am talking about so that may be all BS
bhall is offline   Reply With Quote
Old 06-09-2005, 12:02 PM   #3
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Actually, I've seen a number of B4 engines on eBay go for less than a grand (all parts included but the ECU.)
The real question is, why CAN'T it go from RHD to LHD???? People are swapping JDM STi engines into USDM Subaru's almost daily.
Old 06-09-2005, 12:25 PM   #4
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
it CAN go from RHD to LDH. The issue is with the placement of the second turbo and downpipe etc. This is conveiniently right where the USDM steering rack would be.
The swap is DO-able, but custom fabrication is required to move the second turbo out of the way of the steering stuff. If I recall correctly, there was actually pics on NASIOC someplace a year or so ago describing the issue exactly. Might wanna search.
Keep in mind that the ECU is very expensive too...even if you can find one.
Cheers,
fibuz
fibuz is offline   Reply With Quote
Old 06-09-2005, 12:28 PM   #5
flanders
Member#: 76382
2000 BH
BP Wannabe
Another problem is that you have no idea what the history of the engine is. These engines could be totally worked over.
flanders is offline   Reply With Quote
Old 06-09-2005, 12:42 PM   #6
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
This isn't a problem that is really specific to a B4. Any JDM engine, or even any engine that you don't know the of first hand could have been worked over.
fibuz hit it on the head. The second turbo is the main issue. And custom work like that is usually time consuming=expensive.
Jared
gtwagon941 is offline   Reply With Quote
Old 06-09-2005, 01:19 PM   #7
Teh Legacy
Member#: 9853
to keep your mouth
shut.
The second turbo location was the issue I heard also. A very knowledgable friend told me it could be moved, but a custom up/down pipe would have to be made. I see this as something that would be well worth the extra couple hundred dollars for custom piping.
Would a LINK work as an ECU?
Old 06-09-2005, 02:41 PM   #8
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
the link may work, depending on how the sequential turbo setup is controlled. it will control timing and fuel, but that doesnt help you if it cant control boost properly. I would assume its controlled mechanically, but i really dont know, you would need to talk to someone who lives in japan and owns one, anotherB4 is the only guy i can think of on here. also try scoobynet.
the sequential turbo set ups are not really worth it IMO, its a cool idea and cool to say you have, but true twin turbos would be better, or even a single turbo would be simpler and make more power.
if you really want twin, get a wrx motor and then fabricated your own setup either using internal or external wastegates to control both.
just my opinion though.
Ben
Old 06-10-2005, 03:14 AM   #9
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
LINK wouldn't control the switchover to the secondary very well.
The simple reason that twin turbo B4 motors are cheap on ebay is simply because they are not easy to bolt in. If they were, they would be in the same price range as the WRX or STi motors, or even more as they come with two turbo's instead of one.
When you tally up all the costs and time involved to get a twin turbo B4 motor to work in a swap project, you'd more than likely find it's cheaper, in the end, to use a WRX or STi motor for the project. Not to mention there is more documentation for the WRX/STi motor swaps, more parts, and more ECU solutions.
I've owned three twin turbo Legacies - I've got the single turbo'd twinscroll right now, and a single turbo is where you want to be anyways.
Cheers,
Paul Hansen
www.sevenphotos.com
www.apexjapan.com
AVOjapan is offline   Reply With Quote
Old 06-10-2005, 11:16 AM   #10
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
Cool You called...
For big power, go single, the twin's only advantage is boost LOOOW down (like from 1800rpm ). It'll go like a scalded cat if tweaked right, but as Paul says, the WRX series motor swaps are easier to do and better documented.
Having to mod the piping for LHD on a twin is also a challenge, not to mention needing a bunch of stuff for boost control. If you can find a front clip with the harness, ECU and other bits intact (and want to go to the trouble of the piping surgery), then the TT is a goer IMHO (riding a torque monster around gets surprisingly addictive ).
Cheers
anotherB4 is offline   Reply With Quote
Old 06-10-2005, 01:39 PM   #11
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Thanks for the info! With all the complications I'm starting to forsee, it looks like I'll go ahead and start looking for a Phase 1 EJ22 to build .
what's the deal with the scibbling on the Nurbrugring bWRX Off-Topic 42 09-24-2007 02:50 PM
('93-'01) What's the deal with the performance suspension and muffler? Jeremy Impreza Forum 6 05-16-2001 08:04 PM
OK, I'm lazy - what's the deal with the meet on Saturday? Patrick Olsen New England Impreza Club Forum -- NESIC 5 01-25-2001 06:09 PM
What's the deal with the MYo2? FUBAR General Forum Archive 1 08-30-2000 12:35 AM
