Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-09-2005, 01:16 PM   #1
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Default New Hydra user - gotcha's?
I've just ordered a Hydra from a fellow Nasioc member with wideband. I'm right now running a JDM ECU with EcuTek flash on my ver8 specC swap (completely stock turbo etc.) My exhaust is a bastardized JDM twinscroll downpipe (with cat) to a TXS mid-pipe and axle back. I'll be using a GM boost solonoid, but right now I'm running a MBC becuase my reflash was useless at controlling boost (at my altitude anyway).
I'm looking for installation and start up gotcha's from other Hydra users. I've read Phil's tuning guides and the Hydra manual several times, but I still don't understand if having a cat in front of the rear O2 sensor is ok or not.
TIA
fragment is offline   Reply With Quote
Old 06-09-2005, 01:25 PM   #2
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
I don't think you would have any problems with the cat. I have a catted Helix DP and I don't *believe* it has caused me any problems. Good luck on tuning around the GM solenoid though. It seems someone was trying to tune around the Perrin and it took them a while (but maybe I am imagining things).
good luck,
offset
offset is offline   Reply With Quote
Old 06-09-2005, 01:29 PM   #3
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
That cat WILL affect any AFRs that sensor will see. By products of teh catalytic coverter process include O2, so a O2 sensor AFTER that cat will change what it sees (if it is being used for AFR).
mcowger is offline   Reply With Quote
Old 06-09-2005, 01:58 PM   #4
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
If tuning for the GM sol. is going to complicate things right off the start, I still have the JDM FBC that I can run. Maybe I'll start with that unit first, then try the GM once my tune is roughed in.
As for the Cat and the O2 sensor; I was confused as soon as I saw the installation guide call for that rear sensor to be used. So what is the front sensor used for now? Nothing? Since I'm running the twin scroll system, my front O2 sensor is actually at the top of the downpipe. If the Hydra doesn't use it for anything, why couldn't I run the wideband and/or the OEM rear sensor in that location and plug the rear sensor? Of course I'd have to run the wires for that sensor forward to that location...
Old 06-09-2005, 03:20 PM   #5
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
You don't actually need either OEM sensor so if you like install the WB in the DP. You can select in the software to use only the WB.
As for the boost solenoids the stock is the easiest to tune since I provide a base map but many are getting the hang of tuning the aftermarket solenoids. I can offer advice regardless of which solenoid you decide to use.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 06-09-2005, 03:23 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if you're going to battle with boost tuning, do it once, correctly, the first time. in other words, tune it with the GM solenoid in place. it is a technically superior solution vis a vis a bleed-based system.
jm2c
ken
Old 06-09-2005, 05:24 PM   #7
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
So, if I install the WBO2 in the downpipe, and don't use the rear OEM sensor, can I go back to the OEM in the downpipe once my fuel map is done? And if so, which OEM do I use? The front or the rear?
Thx.
Old 06-09-2005, 07:30 PM   #8
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Installation gotcha: Unless Phil has added a quick disconnect already, getting the wideband connector through your firewall gromment is a real, real SOB and pretty much a two person operation. The reason is the wideband connector is a wide connector and with the OEM wiring going through there already, it's not a walk in the park working it through there.
Old 06-09-2005, 09:14 PM   #9
Element Tuning
Member#: 54918
673 WHP Element
That's why we install it through the shifter boot. Simply pull up the center console, make a slit in the 6x8 rubber grommet and use the rear 02 sensor location.
Thanks,
Phil
Old 06-09-2005, 09:16 PM   #10
Element Tuning
Member#: 54918
673 WHP Element
Thx.
The Hydra can use the WB or the rear OEM 02 sensor. It does not use the front 02 sensor. Once you are done tuning you can use your rear OEM sensor but don't forget to change the sensor source in the software.
Thanks,
Phil
Old 06-10-2005, 02:47 AM   #11
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Well, my buddy does all his stuff through the glove box so everything is nice and secret, so we had to use the passenger side firewall grommet. Believe me Phil, we were both cussing you and your whole generation while doing that. The first time, we put it in backwards too, so we had to go through the whole thing twice.
For Hydra users that still have a DeltaDash license... x99percent Other Engine Management 10 11-14-2006 03:40 PM
Question for hydra users in the DC Metro area Shabib67 Mid Atlantic Impreza Club -- MAIC 5 03-16-2006 02:46 AM
southeast hydra users rjrutzky Other Engine Management 36 01-05-2006 04:11 PM
Calgary hydra users? drdeuce Canada Region Forum 14 09-16-2005 03:24 AM
AEM EMS AND HYDRA Users check this thread.. mistaboosta Other Engine Management 5 12-08-2004 02:47 AM
