Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-09-2005, 02:36 PM   #1
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
Default N/A Exhaust thread
Man the Boosters get all the fun...
but look at this..
TWE 2.5L
Stainless Steel
Equal Length Headers $849.99
Xcceleration/Random's Stainless Steel Super Hi-Flow Catalytic Converter is a work of ART!
It also will increase your Performance by about 10HP and remove many pounds of UGLYNESS!
RS/TS (1999-newer) $449.99 Cat Only.
Xcceleration BAJA Stainless Steel Super Hi-Flow Performance Muffler is a work of ART and adds 10HP!
This is a direct bolt on
$479.99 Axle-Back Performance Muffler 2.5'' PIPE for Baja
$599.99 CatBack Performance Muffler 2.5'' PIPE for Baja
includes: nuts, bolts and gaskets
SO that's about 1700 in parts... Humm this could be good
http://xcceleration.com/leg-engine.htm
holland_patrick is offline   Reply With Quote
Old 06-09-2005, 03:50 PM   #2
blubaja03
Member#: 55144
2001 Panda Fozz
1999 OB wagon
I wish I had some money right about now...Thanks for this info tho.:-D
blubaja03 is offline   Reply With Quote
Old 06-09-2005, 08:39 PM   #3
holland_patrick
Member#: 72014
05 Baja gone
Finally a Dyno Test of our exhaust system.
A complete exhaust system from TechWorks was intalled on this 2003 Baja. The system consisted of: our tuned, equal length, merge collector header (SuperStreet 2.25"); a Random Technology cat section (2.25"); our HighOutput (2.5") mid-pipe with our resonator; and our HighOutput (2.5") muffler section. The car also had a K&N air filter in the stock airbox, but no other modifications.
The dyno was a Dynapak Pro.
Highlights:
- Peak power gain
- Peak torque gain
+ 14.3 hp
+ 13.3 ft-lbs
* Note: The air/fuel ratio indicated that a lack of fuel limited the power output.
The torque peak is moved up in the power band and is still higher at the stock peak and climbing. Our exhaust helps to fill in the major dips in the torque curve just before 3000rpm and at 4500rpm, making for a quicker car that feels smoother (slower?). There is a gain in horsepower before 4000rpm however this is somewhat minimized due to the 2.5" diameter cat-back. This affects the low end torque as well. The larger size was required since the car now has a Stage II Head package (140+whp, sorry no graphs yet). Keep in mind that the car was running quite lean and is waiting for a fuel pump, RRFPR, and a proper intake. It will also get a stand-alone engine management shortly. More info to follow.
Dyno Graph
Old 06-09-2005, 08:39 PM   #4
holland_patrick
Member#: 72014
05 Baja gone
Old 06-09-2005, 10:37 PM   #5
2003Baja
Member#: 52985
really nice!
2003Baja is offline   Reply With Quote
P&L Motorsports Signature Series Exhausts - $100 off all GD Exhausts! Thread Rating: P&L Motorsports Inc. Engine/Power/Exhaust 25 10-20-2009 12:40 PM
Exhaust Thread - What exhaust do you have? JeffyLube General Community 3 05-14-2009 07:27 PM
Another Exhaust thread, sorry:Building a custom performance exhaust? agilitymaneuver Normally Aspirated Powertrain 1 09-02-2008 12:59 AM
Alright who can help me with an exhaust?? YES ANOTHER EXHAUST THREAD!! Silver on Blacks Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 10-09-2005 12:16 AM
Modified exhaust thread reply markcolorado Rocky Mountains Impreza Club Forum -- RMIC 9 07-14-2001 02:11 AM
