Old 06-09-2005, 02:38 PM   #1
04AspenWhiteWRX
Member#: 84330
04 WRX
Default Another AP problem
OK so i figured my used ap is unmarried so I am trying to update it with the new software but i am having a problem with getting it connected to my pc now. Everytime i try and connect it i get an error message on my PC saying Bad Accessport communication (0x86 0x10). Contact tech support. I am using a usb serial adapter. I did called cobb and they didnt help at all. I have an email out to accessecu now too. Any of u guys have an idea whats wrong here?
Phil
04AspenWhiteWRX is offline   Reply With Quote
Old 06-09-2005, 03:23 PM   #2
Member#: 67
1999 Outlasting
the competition.
i think you need to hold down the up& down key when you turn the AP on. or you need to marry it to the car first before it will connect to the PC.
i just got my ST a few minutes ago and i'm starting to load everything right now
Tom
Old 06-09-2005, 03:27 PM   #3
04AspenWhiteWRX
Member#: 84330
04 WRX
sorry i forgot to include that i did put my AP into sync mod and the ap says waiting for PC but for some reason I keep getting an error message when i open the ap map manager on my pc saying bad Accessport communication
Old 06-09-2005, 03:36 PM   #4
johsti
Member#: 36049
2014 FXT Premium
Did you try the map manager's "configure communications" function?
You may need to go into the device manager in control panel/system/hardware, and make sure the map manager is trying to communicate with the AP on the correct usb controller.
johsti is offline   Reply With Quote
Old 06-09-2005, 03:42 PM   #5
thedieselspeaks
Member#: 66475
2003 WRX Wagon
Make sure you have any drivers installed for the usb to serial connector (I doubt there are any but you never know). Make sure that you have the correct port selected in the EDIT: AccessPORT......Configure Communications submenu
thedieselspeaks is offline   Reply With Quote
Old 06-09-2005, 03:53 PM   #6
HANZIE
Member#: 80319
04 WRX
im having a similar problem too. Let me start off by saying i HATE these stupid updates. the directions are straightforward yet is still difficult to accomplish. I have downloaded the newly reporgramed 04 file to change it back from 2005 to 2004 specfic. Well when i final begin to reintialize the update back to 2004 an error messsage contains "Unable to write valid data to accessport"
when i connect to the map manager is reads connected as 2005
unmarried-yes
connected to pc mode- yes
insturctions read over and over- yes
call cobb and the best they can say is send it in.
HAS anyone successfully performed the newly revisied 04 update addressing the stalling issue?
HANZIE is offline   Reply With Quote
Old 06-09-2005, 04:04 PM   #7
04AspenWhiteWRX
Member#: 84330
04 WRX
i have done all that so far and i even tryied it on all my usb's and still nothing it keeps saying the same thing over and over again. How much does cobb charge if I mail the ap to them?
Old 06-09-2005, 04:13 PM   #8
johsti
Member#: 36049
2014 FXT Premium
Yes, I have.
I also had a problem with the AP communicating with my computer.
Open map manager 1.6.2 and click on the accessport tab. Select configure communications, and select autodetect.
If that doesn't work, than go into device manager and see what port the AP is plugged into and manually select it in map manager.
Old 06-09-2005, 04:49 PM   #9
HANZIE
Member#: 80319
04 WRX
i did both and still to no avail.
i guess i have no other choice then to send it to cobb
Old 06-09-2005, 04:52 PM   #10
04AspenWhiteWRX
Member#: 84330
04 WRX
ya I think the main problem i am having is with my pc so i think i might send it to cobb too and have them mess with it. Besides by the time i get it back I should have all my exhaust parts for stage 2
Old 06-09-2005, 04:55 PM   #11
WimpWgn
Member#: 66580
AP has usb connector now???
WimpWgn is offline   Reply With Quote
Old 06-09-2005, 05:13 PM   #12
04AspenWhiteWRX
Member#: 84330
04 WRX
no i have a usb/serial adapter. I do not have a serial port on my pc so i had to buy a usb adpater for it to make it work and i think i wasted my money on it.
Phil
Old 06-09-2005, 05:40 PM   #13
WimpWgn
Member#: 66580
ah, that makes sense. Thanks.
Old 06-09-2005, 06:06 PM   #14
Thumper23
Member#: 11571
yeah, I had to buy a serial/usb adapter too
once I realised I had to install the drivers for the cable :duh: it worked fine
Thumper23 is offline   Reply With Quote
Old 06-09-2005, 06:26 PM   #15
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
What brand adapter do you have?
Could you quote the error messege exactly?
parker/slc/gc8fan is offline   Reply With Quote
Old 06-09-2005, 07:11 PM   #16
04AspenWhiteWRX
Member#: 84330
04 WRX
The adapter I bought at BestBuy is a Dynex Brand made by Prolific and it says USB PDA/ Serial Adapter. I am pretty sure the problem I am having is just with my pc and the cable and has nothing to do with the AP itself
this is what it says on the screen on my pc when i open the window for the AP map manager program and i try to connect it with my AP "ERROR: Bad AccesPORT communication (0x86 0x10). Contact tech support"
I am really about to just step on my pc and send the AP back to cobb and have them program it the way I want it.
Old 06-10-2005, 05:09 PM   #17
04AspenWhiteWRX
Member#: 84330
04 WRX
I just finished printing out a ups lable to ship my AP to cobb and have them mess with it.
Would an AP married to one car work on another car that has another AP married to it? zuczek AccessPort 13 10-24-2006 02:06 AM
another AP boost ? jdbewl01 Engine Management & Tuning 8 06-29-2005 12:35 AM
gawd,,,another AP question,,, mistaare Engine Management & Tuning 2 06-09-2005 12:02 PM
Another AP low boost post... :o( WRexxer Engine Management & Tuning 1 04-20-2005 04:03 PM
Just another AP ? vinithing Engine Management & Tuning 11 08-02-2004 09:33 PM
