Old 06-09-2005, 03:15 PM   #1
RSimport
Member#: 24718
05 impreza RS
white
Default Engine Problems Need Help!!!
Alright, a few weeks ago I posted saying my car was having idle problems. Well, today I took it in to get inspected(in PA) and they couldn't even get the car to start. Turns out I need a new coil pack. So, I ran down to my local subaru dealership picked one up and installed it. So, I sit down and start the car same damn thing as before but it at least started. It seems to be misfiring on the 4th cylinder. At that point I replaced the spark plug wire to the 4th cylinder and the same thing.So, we did get the car running and it seems when ever we beat on the maf censor it helps for a couple seconds but then goes back to misfiring.
So, my questions
What else could make this happen? Has anyone else had problems like this?
Thats all I can really think of right now any input would be great. Thanks!
Chris
RSimport is offline   Reply With Quote
Old 06-09-2005, 07:40 PM   #2
orndog
Member#: 34670
2013 No gears!
Saltine American
Get a new MAF sensor.
Put it on.
If it helps = profit.
If it doesn't = return it.
orndog is offline   Reply With Quote
Old 06-10-2005, 08:40 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
electrical parts are not an item you can return...
all sales are final via subaru
which car do you have?
Jamie
Old 06-10-2005, 08:50 AM   #4
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
I didn't see your other post, but did you change the spark plug itself? if not, I'd try that also; if so, I'd take it back out and make sure that the plug is gapped correctly.
If the Coil Pack, Plug Wires, and Spark Plugs aren't the problem, try cleaning the MAF Sensor. Take it off and use some rubbing alcohol (medical grade and clear) and some q-tips to GENTLY clean the wire in the sensor. From there, I'm not sure.
Perdue is offline   Reply With Quote
Old 06-10-2005, 11:59 AM   #5
orndog
Member#: 34670
2013 No gears!
Saltine American
Jamie
Autozone.
Old 06-10-2005, 12:54 PM   #6
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
I was actually told that the MAF Sensor was a dealer only part...if that's true (I haven't checked), then Autozone isn't going to help any either.
Old 06-10-2005, 01:40 PM   #7
orndog
Member#: 34670
2013 No gears!
Saltine American
Depends on the vehicle. Advance Auto does list 3 for a 1998 Legacy L.
Old 06-10-2005, 05:00 PM   #8
RSimport
Member#: 24718
05 impreza RS
white
alright just got the car, back it wasn't the maf itself because that part is like 355.00 it was a sensor that was apart of the maf which was only 50 bucks now the car runs great. Thanks for the input guys
Chris
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 09:59 AM
engine problems..need help.. fosingwo Subaru Conversions 5 10-27-2006 03:09 PM
Engine problems - Need help ASAP! Soon2BturbodRS Normally Aspirated Powertrain 13 06-25-2005 06:08 PM
engine problems..need help gotawd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-10-2005 09:00 PM
toyota engine problem, need help. spike Off-Topic 25 01-11-2004 05:25 AM
