Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 06-09-2005, 11:37 PM   #1
NorCal11.7
Member#: 55879
2000 Impreza 2.5 rst
Blue Ridge Pearl
Question Greddy Guages and Controller Shut off periodically
ok, so i have a set of greddy guages, Boost, EGT, & Fuel Pressure along with a Greddy Profec B controller. It seems that whenever i run my heater for a while they shut off, and the same if it sits in the sun for a while. im thinking that the heat may be causing too much rsistance in the circuit. has anyone had this problem before? do you think it could be because of the heat/resistance in the wires?
NorCal11.7 is offline   Reply With Quote
Old 06-10-2005, 01:35 AM   #2
scuBdoB17
Member#: 63650
1997 Impreza 2.2L
Green
First of all, when you installed the gauges where did you ground the wires? Second of all, I pretty sure that you are not getting thermal runaway through a wire. Thermal runaway usually has to do with an amplified circuit where the Q point is set either at cutoff, or saturation. Changes in the temperature can move the Q point up or down the load line which causes heavy distortion, and fries the circuit, so i dont think that is your problem. Let me know where you grounded your wires because as of now, i am thinking that is your problem.
scuBdoB17 is offline   Reply With Quote
Old 06-10-2005, 03:05 AM   #3
NorCal11.7
Member#: 55879
Blue Ridge Pearl
i bought the car with them already wired, but i'll let you know once i take a look.
Old 06-10-2005, 03:40 AM   #4
NorCal11.7
Member#: 55879
Blue Ridge Pearl
The thing that really confuses me is that they will light up and everything, except for the boost controller, but no guage movement? does that help the diagnosis?
Old 06-10-2005, 04:19 AM   #5
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Same thing happened to my Greddy boost guage (electronic, non PHW). It lights up, but the guage doesn't move. Has anyone tried opening the sender unit?
illmatic is offline   Reply With Quote
Old 06-10-2005, 12:40 PM   #6
NorCal11.7
Member#: 55879
Blue Ridge Pearl
well at least im not the only one that this has happened too... but i dont have any wiring diagrams or anything for these guages, but i should be able to figure it out
Old 06-10-2005, 04:01 PM   #7
illmatic
Member#: 3536
Replacement boost sensors run for about $60 for the electronic gauge and $120 for the PHW guage. I noticed the greddy and defi look similar and could be interchangeable. I wonder if the actual senser inside the sender unit is replaceable.
Cruise Control Shuts Off With Headlights On master c Electrical & Lighting 3 12-31-2008 03:24 AM
Help, defi guage and control link install Archillion Electrical & Lighting 5 11-09-2007 09:17 PM
Maddad lectronic guages shut off when lights turned on Honest Bob Electrical & Lighting 5 07-02-2006 01:15 AM
Help: Random CEL and Random Shut Off FatStraws Texas Impreza Club Forum -- TXIC 38 07-22-2005 08:17 PM
Installed some Greddy guages and now I her ea a noise skyhigh420 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-26-2001 11:52 AM
