Old 06-09-2005, 07:58 PM   #1
Ice Master
Member#: 44662
2002 2.5 TS
Default Will my 2002 injen intake fit on a 2003
Title says all,
Will my injen cold air intake made for the Impreza 2.5 2002 will fit in a Impreza 2.5 2003. I was showing it to a possible buyer when we realise that the 2002 as one more hose going to the intake than the 2003. The two hoses coming from each heads of the engine are the same but There is a hose going from the throttle body area that goes in the intake on 2002 that is not present on the 2003.
So what are the difference of the engine between 2002 and 2003?
What is this extra hose that i got on my 2002?
Does injen make a different intake for the 2003?
Could we still install the CAI and plug the extra hole?
need help please.
Ice Master is offline   Reply With Quote
Old 06-10-2005, 01:29 AM   #2
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
Yes it will work. I am using an 00-01 specific (02 too I think) on my 04. You just have to plug one of the vaccum holes. I don't know what the extra hose is for, but I think that it is just another vaccum hose. Injen as of yet doesn't make one for the 03 & 04 models. It will work
impr25rs is offline   Reply With Quote
Old 06-10-2005, 10:19 AM   #3
Ice Master
Member#: 44662
2002 2.5 TS
So cobb makes a intake for the 00-02 and another one for the 03-04. Its says for the 00-02 with out IAT and for the 03-04 with IAT.
so what is an IAT?
Old 06-10-2005, 12:39 PM   #4
piker28
Member#: 22664
this stupid little sensor in the intake, if you look in the airbox its like this stupid plastic thing, kind of hard to describe
i am not sure on how injen works and all but on the most part no the intake would not just work, like on the cobb if you tried to use a 00-02 intake on a 03 youd have to drill a hole in it for the IAT sensor its not to bad but another bump in the road, plus prob have to plug a vacuum plug
piker28 is offline   Reply With Quote
Old 06-10-2005, 01:40 PM   #5
impr25rs
Member#: 60162
04 Aspen RS
Here is a pic of what I did on my 04, hopefully this will help a little
The IAT sensor is the left wording, the plugged vacuum line is the middle, and the vacuum lines are the right side. Small pic sorry
I don't know about the Cobb one, sorry. Hopefully someone will chime in on it.
Old 06-10-2005, 02:22 PM   #6
Handsdown
Member#: 29355
intake air temperature sensor can be introduced into the intake anywhere inbetween the throttle body and the filter. i doubt you'll have a problem.
Handsdown is offline   Reply With Quote
Old 06-10-2005, 05:38 PM   #7
Ice Master
Member#: 44662
2002 2.5 TS
Alright thanks guy for the replies.
will a 2002 wrx ecu work on a 2003 wrx? scoooby03 Engine Management & Tuning 4 09-11-2011 03:14 PM
will 2004 sti wheel pattern fit on a 2003 wrx..???? mike739wrx Tire & Wheel 1 04-03-2009 12:06 AM
Will a 2005 STI up-pipe fit on a 2003 WRX??? 1FSTREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-27-2006 01:11 PM
Will a 2004 STI trunk and side skirts fit on a 2003 WRX?? 1FSTREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-21-2006 10:46 AM
will a 04 sti intake fit on an 06 tenabekid Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-23-2005 06:22 PM
