Old 08-04-2001, 12:58 AM   #1
Rubasu
Member#: 1418
MY00 2.5RS
Default difference between TO4B and TO4E..
the title says it all. I need to know the differences between these so I can make a choice of which to buy. Thanks
Rubasu
www.scoobytechnics.com
Rubasu is offline   Reply With Quote
Old 08-04-2001, 11:26 AM   #2
Rubasu
Member#: 1418
MY00 2.5RS
thanks
Rubasu
Old 08-04-2001, 12:42 PM   #3
t.rod
Member#: 1447
2000 Impreza
2001 Dodge 2500
the TO4B it older technology than TO4E.
Well I know of the T3/TO4E.
Minnam Turbo kits used the T3/TO4B with there kits.
t.rod is offline   Reply With Quote
Old 08-04-2001, 01:02 PM   #4
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Huh!
Are you sure that Minnam turbo kits use(d) the T3/T04B with their kits? I'm almost positive that it was/is in fact a T04E . T
Kevin Thomas is offline   Reply With Quote
Old 08-04-2001, 11:42 PM   #5
t.rod
Member#: 1447
2000 Impreza
2001 Dodge 2500
I hope it is the T3/TO4E.
Old 08-04-2001, 11:56 PM   #6
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Go to the horses mouth... er, uh... Turbonetics.
www.turboneticsinc.com
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 08-05-2001, 08:38 PM   #7
RyanC
Member#: 2634
2011 STi
weiss
My minnam turbo is a 'B'. The 'E' has a bigger compressor wheel iirc. FWIW when I had my turbo installed RalliSpec said they never had seen the same turbo twice in any of the minnam kits they'd installed.
RyanC is offline   Reply With Quote
Old 08-06-2001, 09:22 AM   #8
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
edit(courtesy): I just got a T04E. Read below.
wcbjr is offline   Reply With Quote
Old 08-06-2001, 11:54 AM   #9
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
The turbo, T04E, was delivered to the UPS center here at 5:00 this morning. It should arrive at my door this afternoon provided nobody had to sign for it. I will post pictures, as good as I can get, and a review as soon as I can.
Old 08-06-2001, 10:17 PM   #10
IMPBOY
Member#: 65
I have a question. The turbo kit I just bought coes with T3/T4B. the turbine side is turbonetics T3 and compressor is supposely Garrett T4B. My question is, do I really have T4B? I just want to conform the type and find out the spec of it. The guy who sold me the kit tells me it's T4B but I can't really trust his words. The only info I have about the compressor is it has "Garrett" and "A/R .42" written on it. The compressor is slightly bigger than the turbine housing which is T3. Can anyone please tell me what compressor I have? The Garrett website doesn't tell me anything.
IMPBOY is offline   Reply With Quote
Old 08-07-2001, 03:58 PM   #11
GGrahnVI
Member#: 7190
By the information given, there is no difference in the two turbocharges. T04e or b is referring to the compressor housing. Go get the box with all the specs and write us back with all those nifty turbo specs that don't seem to make any sense.
For all intent and purposes, the people who manufactured (who is it?) your kit will have the best information on this.
GGrahnVI is offline   Reply With Quote
Old 08-07-2001, 04:10 PM   #12
subachad
Member#: 8488
Teal
Garret, turbonetics, air research, they are all the same. If you would like more info on your turbo, you should really check out www.turboneticsinc.com
As for the A/R of .42, look at the compressor maps and it will let you know the A/R you want for the size of motor you have and how much power you want.
Chad
93 1.8T
P.S. I barely understand the compressor maps, so good luck.
Old 08-07-2001, 05:24 PM   #13
RyanC
Member#: 2634
2011 STi
weiss
There is some good info here as well: http://www.turbofast.com.au/balstd.html
It looks like you can tell what you have by measuring the wheels. I don't see an a/r of .42 listed on the page though, but I don't know how complete the listing is. HTH
Old 08-07-2001, 10:55 PM   #14
IMPBOY
Member#: 65
The problem is, there is no document abot the turbo's spec in the kit. The turbo itself was packaged in a plain box without anything. I could not find any compressor that has .42 A/R and that's why I was a little confused. I asked the person who made me this kit but he wouldn't tell me anything. I don't even know what type of compressor wheel I have. From the look of the trubo itself, it looks like it has been used before because there's little oil inside the oil feed/return holes and exhaust residue on the turbine wheel. I don't know if that's from testing the unit at the factory or if I got a used turbo but the fact that he doesn't tell me the spec of turbo bothers me a little.
Old 08-08-2001, 09:18 AM   #15
RyanC
Member#: 2634
2011 STi
weiss
Impboy, can you measure the wheels and see if that tells you anything? In a worst case scenario you can always send it out for a rebuild and then you'll really know what you have
Technical difference between "Bar and Plate", "Fin and Tube"? FromageTheDog General Community 14 11-10-2005 09:52 PM
Suspension differences between wagons and sedans and my03, and my04. jawbrkr Brakes, Steering & Suspension 16 08-03-2005 07:41 PM
Difference between AWD and 4WD? And other questions... AWD987 Newbies & FAQs 7 01-15-2003 11:00 PM
Caliper difference between sedan and station wagon??? Aspen Legacy Forum 2 11-13-2000 09:34 PM
Difference between 91 and 92 Turbo Legacys?? nd4spd Legacy Forum 3 09-15-2000 02:28 PM
Message Board Statistics All times are GMT -4. The time now is 03:52 AM.
