Old 06-10-2005, 04:58 PM   #1
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Default how long did your stock battery last?
Well mine bit the dust for no apparent reason today, i have an 03 with 38,000 miles and the warranty was over at 36,000 . Is it normal for a battery to only last that long? BTW i didnt leave anything on, i checked for a draw on my electrical system and their was none, only like .02 but thats normal. what might of cause this early failure?
blackie is offline   Reply With Quote
Old 06-10-2005, 05:10 PM   #2
Hayes
Member#: 11808
My 2000 Forester OEM panosonic lasted 4+ years. My daughters Hyundia battery lasted 2+ years. My Fl temps may be causing early demise. Up North I'd get 6 years easy.
Hayes is offline   Reply With Quote
Old 06-10-2005, 05:36 PM   #3
pityr
Member#: 31719
check the water level. Thats about when my battery started to get low. Filled it back up and it worked fine.
pityr is offline   Reply With Quote
Old 06-10-2005, 05:57 PM   #4
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Yep, when you change the engine oil you should check the battery water levels too. Only takes about 5-10 minutes to check all compartments and add enough distilled water if needed.
My battery: still kicking after 2 years 7 months with 63k miles on a 2003 WRX sedan. Car gets started 2-4 times a day (go to work, come home from work, run errands if needed). Southern california weather. Only gets below freezing for afew weeks a year in the winter and gets over 100 for afew months in the summer.
Old 06-10-2005, 06:16 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
you know it's just a matter of time until the "OEM battery haters" booger up this thread...
Couple of things to keep in mind - the OEM battery isn't very high powered (350-ish cca) and it is not maintenance free - you need to keep an eye on the water levels (as already pointed out)
Old 06-12-2005, 12:02 AM   #6
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
How can I refill the water? Mine is just above the low level line. Is it okay?
wrx2 is offline   Reply With Quote
Old 06-12-2005, 12:17 AM   #7
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
Had it since April 02..still working and I have quite few electronics.
enewtabie is offline   Reply With Quote
Old 06-12-2005, 12:26 AM   #8
Psydotek
Member#: 44168
2003 Yellow WRX
Unscrew the 6 plugs on top of the battery, but be careful not to let dirt fall into the battery and not to let any fluid on the plugs drip anywhere (it could be sulfuric acid). Then just pour some distilled water (a cup and small CLEAN funnel work best) into the chamber until it just makes contact with the little tab hanging down just inside the hole. Then just screw the plugs back in and you're set.
Old 06-12-2005, 12:29 AM   #9
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
i still have my stock subaru battery. (6 years old now)
svek is offline   Reply With Quote
Old 06-13-2005, 03:14 PM   #10
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
Thanks!
Old 06-13-2005, 04:00 PM   #11
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
mine just died today - Oct 01 through June 05
32K miles
Big_Hitter is offline   Reply With Quote
Old 06-13-2005, 10:02 PM   #12
jonney_boy
Member#: 28747
06 WRX
mine died last month...
just a tad over 2 years old and about 45,000km on the odo....... no additional electronics and the water level was kept up... it just decided to die (one day the car won't start).
Replaced it with a red top and so far so good....
jonney_boy is offline   Reply With Quote
Old 06-13-2005, 10:35 PM   #13
Fernely
Member#: 6824
2008 QSM Leg. spec B
Pastelito Racing/ SFSOC
Still have my oem one on a MY99. I just check the water levels but she statrs up fine every time.
Fernely is offline   Reply With Quote
Old 06-13-2005, 10:48 PM   #14
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
9 months and 9000 miles. I gotta Optima battery now but my car was sitting for months at a time undriven in winter....
ScoobyNubieToo! is offline   Reply With Quote
Old 06-15-2005, 12:48 AM   #15
pudnana
Member#: 89071
2000 Blue 2.5 RS
2004 Java WRX
First six months I had my 2004 wrx I had the battery replaced 4 times, the current one has been in for nearly a year.
pudnana is offline   Reply With Quote
Old 06-15-2005, 01:31 AM   #16
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
just under 2 yrs and somewhere around 20K miles
Impreza2003 is offline   Reply With Quote
Old 06-16-2005, 11:54 AM   #17
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
stock battery since apr. 01 and 101,000 miles..
and still working...
just keep an eye on the water level.
dm
dwmoss_68 is offline   Reply With Quote
Old 06-16-2005, 04:07 PM   #18
Handsdown
Member#: 29355
umm... opening up your battery isn't something i'd reccomend to any idiot on the internet.
they seem to start to have trouble after 30,k miles. mine's getting low on distilled water. the thing is, if you breathe wrong into the fluid it's going to make your battery useless.
better just to get a better battery.
Handsdown is offline   Reply With Quote
Old 06-16-2005, 04:22 PM   #19
svek
Member#: 82259
1999 impreza 2.2L
same with me, i guess the older ones had better batteries than the new ones. i see a lot of "replaced it after 6 months in my rex"
Old 06-17-2005, 01:51 AM   #20
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Mine lasted a little over 2 years.. replaced with e Odyssey 680MJ and going good so far.
Jay
Diversion is offline   Reply With Quote
Old 06-17-2005, 10:04 AM   #21
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
you can't be serious - it's a lead acid battery - wipe off the top, unscrew the holes, top off each cell with distilled water, and you're good - not rocket science. While there are certainly things you could add to the electrolyte which would kill them, breathing on them isn't going to do it - as long as you take your time and wipe down the top first, nothing bad is going to happen to you or the battery.
Old 06-17-2005, 10:23 AM   #22
Psydotek
Member#: 44168
2003 Yellow WRX
I've even spilled small amounts of dirt into the battery, purely by accident mind you (it's hard to wipe off dirt that finds it's way into the space around the plug...) I think the acid probably just eats up whatever finds it's way in. I'm not saying you shouldn't be careful with getting dirt into the battery, but just a little care will keep it going for a long while. The term "Maintenance Free Battery" is really a misnomer...
Old 06-17-2005, 12:46 PM   #23
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
stock battery 12/02 - present
45k mi and gagillion watts of drawn power
still going strong.
RR
Rapid_Roo is offline   Reply With Quote
Old 06-18-2005, 11:32 AM   #24
Division By Zero
Member#: 7555
Lasted 27k miles/30 months. However, it wasn't replaced under warranty because the car wasn't driveable and by the time it was on the road it was past the 36 month warranty. That OEM battery isn't that good of product but of course many OEM batteries really aren't that great.
Division By Zero is offline   Reply With Quote
Old 06-18-2005, 11:39 AM   #25
foreSTir
Member#: 43077
05 OB-XT
GRP
High heat kills batteries. TX seems to be pretty hard on batteries. I'm getting 3-4 years battery life, compared with over 9 years on OEM battery up North (freezing temps apparently not as hard on the battery life, but more demanding on cold cranking amps).
foreSTir is offline   Reply With Quote
STi Guys...how long did your stock brakes last? rxer311 Brakes, Steering & Suspension 15 01-18-2009 12:43 AM
How long did your stock rotor last? Junichi imports Vancouver Impreza Club Forum -- VIC 24 09-14-2007 09:59 PM
How long did your stock battery last? Is mine just dead or is something else wrong? rex n effect Mid Atlantic Impreza Club -- MAIC 32 10-20-2006 03:33 PM
How long did your stock struts last with aftermarket springs? Red Rexx Brakes, Steering & Suspension 0 03-25-2005 11:13 AM
How long did your stock struts last? Matt Monson Technical Forum Archive 0 09-12-2000 12:46 PM
