Old 06-10-2005, 04:07 PM   #1
13secwrx
Member#: 62106
2002 Wrx
465Whp SZ'D..when running
Default Stoptechs vs Sti brembos
Which one do you think is better. I am upgrading my front brakes...
Opinions and facts needed/wanted.
thanks
13secwrx is offline   Reply With Quote
Old 06-10-2005, 04:21 PM   #2
coolblue05
Member#: 39169
2008 Cayman S, C63
Tuned Perfection
stoptechs, for sure. I love mine.
coolblue05 is offline   Reply With Quote
Old 06-10-2005, 04:24 PM   #3
kaos200
Member#: 2692
+1 for stoptechs here, I cant complain about them really (except the price tag )
but they so far have had no issues, street and track use.
The STi Brembos are also heavier and to me, since it's a stock piece I like the extra "bling" of a red aftermarket caliper, may sound lame to some, but thats just my 2c.
kaos200 is offline   Reply With Quote
Old 06-10-2005, 04:35 PM   #4
04RCSTI
Member#: 65694
MDC Forever
Black '06 STI
doest sound lame, both colors are great. Stoptechs are better..
04RCSTI is offline   Reply With Quote
Old 06-10-2005, 04:39 PM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
If for nothing else the Stoptechs are better because of the lighter, better cooling 2-piece floating rotor. Also, there are a few more wheels that will fit over Stoptechs that won't fit over the Brembos.
mav1c is online now   Reply With Quote
Old 06-10-2005, 04:40 PM   #6
Roy Lin
Member#: 38890
Stoptechs are designed specifically for the WRX by experts.
I'd rather get the stoptechs... but i cheaped out and got the non brembo 4-pots instead
Roy Lin is offline   Reply With Quote
Old 06-10-2005, 05:16 PM   #7
0db
Member#: 33879
2003 WRX Sporkwagon
And I suppose the STi's brakes were chosen by pulling names out of a hat?
0db is offline   Reply With Quote
Old 06-10-2005, 05:58 PM   #8
Roy Lin
Member#: 38890
no, but the stoptechs were deisigned for the specific application for the WRX. I'm assuming the STi probably has different plumbing, balance, etc.
No need to be a sarcastic dOoSH noZzlE, mmmmmkay?
PS And yes, the STi's brakes were designed by a million monkeys with computers who also happened to write some shakespeare
Old 06-10-2005, 06:11 PM   #9
srf
Member#: 50646
2004 WRX STi
Java Black
Stoptech shaved 16 pounds of unsprung weight over stock according to my scales. =)
srf is offline   Reply With Quote
Old 06-10-2005, 06:15 PM   #10
13secwrx
Member#: 62106
2002 Wrx
Ohh....im giddy already...wont the extra rotating mass of the rotor slow me down a tenth or so...or am i worried for no reason. I am all about speed..but I am realizing that i have to stop also
Old 06-10-2005, 06:36 PM   #11
srf
Member#: 50646
2004 WRX STi
Java Black
I'm not sure how much of an effect it has on acceleration... I forget is the rule of thumb that one pound of unsprung weight is equal to ten pounds of sprung weight, or is that for rotating vs. non-rotating weight?
Old 06-10-2005, 06:46 PM   #12
ndw1138
Member#: 32433
2005 STi V370
black
On a 3000 lb car every 7 pounds shed is equal to a horsepower (effectively in accleration).. Plus you obviously get a better handling/stopping car. Reducing weight is signicantly better than adding power - at least for getting around a track..
As for brembo's versus stop-techs. As for stop-techs versus STi Brembo's.. Absolutely postively no question - the stoptech are superior. Superior in feel, superior in weight, superior in design, and proven durability (how many touring cars are now running stop-techs and giving props to them?). Now brembo's big brake kits are a different story. The comparision becomes closer, but then the cost of the brembo's is so much more it again favors the stop-techs without a doubt.
My expirence with stop tech and brembo -
05 STi with stock brembo's/pads/rotors/lines
05 STi with front slotted rotors and aluminum hats, steel lines, motul fluid and hawk t-10/14 pads and ferodo 2500 (for street)
03 WRX stock
03 WRX with steel lines, superblue fluid, stoptech calipers/rotors front, rear stop tech rotors and axxis ultimates and hawks for track
AND finally to make things more entertaining Brembo/Porsche GT3-R racing brakes on my old 996 - which are still the best brake package I personally have ever felt but cost about 6K.
nathan
ndw1138 is offline   Reply With Quote
Old 06-11-2005, 11:17 AM   #13
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
thanks
What do you use the car for? Why do you want a BBK?
Old 06-11-2005, 11:30 AM   #14
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
http://www.rallyperformance.com/brakes.shtml
scroll to bottom.
6POT AP caliper w/ 378mm rotors, thats huge!! about $1K more than stop techs though.
jam69007 is offline   Reply With Quote
Old 06-11-2005, 03:33 PM   #15
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I'm surprised no one has mentioned brake bias. The Stoptechs are designed around the WRX stock brake system. They take into consideration the rear brakes and bias a bit of braking rearward. The STi Brembos are designed around the full Brembo F/R package. So if you were to mount just the front STi brembos you will have a heavier front brake bias than stock and will most likely have longer stopping distances (actually, take a look at Stoptech's whitepapers regarding brake bias). If you were to get the rear brembos at the same time then your bias would be fine. IMO, the STi Brembos are more than enough brake as a full kit than most people would need. The only limiting factor are pads and fluid. Things can be improved if you go to brembo's better ventilated and lighter 2 piece rotors.
as an aside, I had a set of the Brembo GT-R kit in hand yesterday for the STi. Those caliper are much lighter and oh so sexy. Fully forged with ventilated (cross drilled) titanium pistons (8 of them per caliper). $10k for brakes, oh yeaaahhh.
Arnie is offline   Reply With Quote
Old 06-11-2005, 03:49 PM   #16
slickvic
Member#: 29727
2003 Impreza WRX
another extremely happy stoptech owner.
Far and away the best modification I have made to date.
slickvic is offline   Reply With Quote
Old 06-11-2005, 03:53 PM   #17
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
can you post a link so i can read about them please.
have you seen the newest ENDLESS calipers 12POT, 6mini pistons on each side, pretty crazy!! i seen them in the latest issue of Modified Mag.
Old 06-11-2005, 05:01 PM   #18
moremaga
Member#: 12179
2002 WRX RA gears
Blk
Smile Stoptechs
Another vote for stoptechs! Best performance for the $$$.
moremaga is offline   Reply With Quote
Old 06-11-2005, 11:39 PM   #19
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Old 06-11-2005, 11:45 PM   #20
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
damn those are hot!
the link says they are for a porsche, do they make them to fit an sti too?
Old 06-11-2005, 11:49 PM   #21
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Yes, the one's I had in my hand yesterday were for an STi. 8 pot with the cool drilled ti pistons. Wish I had my camera with me. That shop also had the JIC Mazda RX8 drift car there being worked on.
Old 06-12-2005, 01:57 AM   #22
STI4ME
Member#: 6034
It's Soo-BAH-roo
I agree that the Stoptechs are awesome, but knockback is just so damn annoying. Just backing out off my drive ay, I get knockback by the time I get to the end of the street. And of course, it's worst right after you take a sharp turn. It's not air in the hydraulic system. Most likely due to the very weak WRX hub/bearing assembly. Any of you guys have the same problem?
STI4ME is offline   Reply With Quote
Old 06-12-2005, 02:02 AM   #23
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
That's a pretty well documented issue with stoptechs and a wRX, as well as the brembos on 04STis. the 05 sti seems a wee bit better but some still suffer from it.
Old 06-12-2005, 02:12 AM   #24
STI4ME
Member#: 6034
It's Soo-BAH-roo
Yes, I've read through all the posts that are knockback-related. But if you read through most of them, folks are getting symptoms of kb in "racing" condition, which I can totally understand. None of these posts ever mentioned kb problems in daily driving situations. I love how my Stoptechs resist fade, stops shorter, and most of all does not trigger the ABS as much as the stocks system. I'm looking forward to the end of our auto-x season when we have an endurance run of 5 non-stop laps and not having to worry about fade. But it is really annoying when light duty daily driving can cause kb.
Old 06-12-2005, 02:42 AM   #25
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I hear you. Have you looked into replacing your front bearings for a fresh set? Perhaps a fresh set will have less play and lead to less KB. Our local suby shop usually completely flushes and cleans the original grease and replaces with hitemp race grease for better life. I recall some folks looking into some type of spring system behind the pistons to push them out? Who knows if that is even possible.
04WRX -> 02WRX brakes? STi Brembo front vs Stoptech BBK PinnacleChronos Brakes, Steering & Suspension 11 02-26-2007 11:51 PM
STi Brembo vs Stoptech jameslippert Brakes, Steering & Suspension 2 12-02-2006 08:59 PM
Will stoptech rebuild STi brembos? clamdip Brakes, Steering & Suspension 10 09-05-2006 12:12 AM
Stoptech bbk vs. Sti brembo mathetes Brakes, Steering & Suspension 12 04-21-2006 01:17 PM
STi Brembo take offs Vs StopTech? 03MBP Brakes, Steering & Suspension 52 02-22-2006 09:25 PM
