Old 06-10-2005, 04:52 PM   #1
tcam33
Member#: 54515
05 WRX STi
WR Blue
Default I need a flasher (LED's)
Installed LED tail lights, now I need a flasher that does not flash fast when it thinks a bulb is out. I don't want to add resistors, I just want a flasher that works with our cars. Has anybody found a no load electronic flasher that will actually work, I've gone through 2 now (auto parts stores )
tcam33 is offline   Reply With Quote
Old 06-10-2005, 05:26 PM   #2
assassin_2.5
Member#: 86976
no dice man so far ur gonna need resistors bot a set should only run u 20$ and thats canadian mes from toronto
assassin_2.5 is offline   Reply With Quote
Old 06-11-2005, 03:13 AM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
So the flashers you have tried are the electronic no load ones? funky, as that usualy works.
PARANOID56 is online now   Reply With Quote
Old 06-11-2005, 07:45 AM   #4
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
what i did on my my01 RS was i installed a dual filament bulb....with a small piece of foil to make it use both filaments ar blinkers.....this used enough load throuhg the series to make them flash at regular speed....i know its nothe most scientific way...or maybe not the most "non-ghetto" way but hey it worked..dont know if a dual filament replacement will fit, but hey? it would be the 7443 not the 7440...or vice versa dont remember really
ATX25RS is offline   Reply With Quote
Old 06-11-2005, 10:26 AM   #5
tcam33
Member#: 54515
05 WRX STi
WR Blue
Update: I kinda hotwired the one I had after looking at the pinout of the flasher and the cars wiring diagram and it works as advertized. So now I just have to find a place the sells this particular Grote flasher.
Old 06-12-2005, 03:30 PM   #6
R_W
Member#: 76896
Disclaimer: I work for the company whose products I'm about to mention. I'm familiar with my companies products, but will gladly assist with any other company's. Not trying to push stuff, just trying to help...
If you go to Autozone, Advanced, Pep Boys, etc, a Tridon EP-34 is a direct plug in. It will behave exactly like your stock flasher.
If you want to fix the LED problem without resistors, you can get an EP-37. You have to get this from NAPA, I don't believe the others carry it. It is only a 2 pin flasher, but it will work. Plug it in one way, and if it doesn't work plug it in the only other way. The advantage is this is also a high lamp flasher, and can handle towing applications up to whatever the vehicle wiring can handle. Disadvantage is that you don't get outage (fast flash on bulb out) function, but you lose this with LED's anyway.
RW
R_W is offline   Reply With Quote
Old 06-14-2005, 06:18 PM   #7
tcam33
Member#: 54515
05 WRX STi
WR Blue
^^^ Thanks I'll try the 37
FS: DC area Random stock parts need gone!!! Distinctive Engine/Power/Exhaust 7 08-10-2010 07:31 PM
FS : St. Louis 2005 STI longblock, good compression. Just got pulled need it gone!!! deuce189 Engine/Power/Exhaust 10 06-05-2010 03:33 PM
A/C Pressure switch 94 Leggy? Need Help DjKlown Legacy Forum 2 06-02-2010 05:42 PM
Clear-flasher light PsychO Interior & Exterior Modification 7 08-23-2001 07:33 PM
High-beam flashers BugBomb General Forum Archive 18 05-24-2000 12:36 AM
