Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-11-2005, 10:38 PM   #1
Samuris
Member#: 89001
Question Upgrading
Last year I bought an 04 baja sport because I couldn't afford the turbo model. I really enjoy my baja but I just wish it had more power. What are my options to put some pony's under the hood?
Samuris is offline   Reply With Quote
Old 06-11-2005, 11:00 PM   #2
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
exhust,CAI,ECU retuning.
holland_patrick is offline   Reply With Quote
Old 06-11-2005, 11:47 PM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
Thats about it until you start swapping cams and taking steps to raise compression etc.
I dont know if you have a 5 speed or an auto. You could add a lighter flywheel and some lighter pullies to make it alittle more responsive if you want.
Its going to be alittle difficult to get a lot of power out of that engine, but you should be able to liven it up a bit and make it alittle more fun.
Hawk296 is offline   Reply With Quote
Old 06-12-2005, 12:55 AM   #4
Samuris
Member#: 89001
I bought the automatic
Old 06-13-2005, 08:46 AM   #5
holland_patrick
Member#: 72014
05 Baja gone
here is something I pulled off of the TWE website
Ride: 2003 Subaru Baja Owner: Tyler R
Engine Mods:
TechWorks Stage II Cylinder Head Package, TechWorks SuperStock Header, Random Tech Super High-Flow Cat, TechWorks HighOutput Mid-Pipe with Resonator, TechWorks High Output Stainless Steel Muffler, PRM Intake
Chassis Mods:
Whiteline 18-22mm Adj. Anti-Swaybar
Old 06-14-2005, 09:06 PM   #6
10.5sec1992AWDtalon
Member#: 63681
I did the following to mine and noticed better throttle response/power gains,
so Unless you want to spend big money for small gains with an expensive poor fitting CAI do this:
1.Remove baffle in front of grill blocking engine cold air inlet to allow a bit of ram effect
2.remove all the water drain jugs hanging on the inlet pipe except the last smallest one and cap off all the openings.
3.Grind out all the baffles in air cleaner housing
4.Install K&N filter
You will hear a lot louder air inlet noise when going WOT now also...
5.Replace spark plugs with NGK irridium
6.Replace plug wires with Magnecores
Get rid of excess weight too, I pulled off the roof crossbars and removed the bed extender and all the floor mats( I hate mats anyhow) If you're daring get rid of the spare tire/jack too and just carry a plug kit and a can of fix a flat for around town driving. This sheds around 100 pounds. Go one step further and only fill the gas tank 1/2 way, that will keep you down about another 48 pounds. Finally put the tire pressure at the max, less rolling resistance.
I know, it's all little crap, but all added up I'll bet it equates to about a 25 HP gain with the weight reduction figured in. That's a pretty big 15% gain for little money.
Too bad I didn't bother to get a before and after at the track(I only live 10 minutes away from the drag strip) but I've done enough mods and racing over the years to know that I can feel meaningful gains. The motor now revs much faster to WOT 6k shift points and feels like there's more HP.
10.5sec1992AWDtalon is offline   Reply With Quote
Old 06-14-2005, 10:32 PM   #7
Hawk296
Member#: 14555
1995 Impreza L
Baja
NKG irridiums are what the turbos come with. Ive noticed my 2.5L impreza seems to run excellent on simple NGK coppers. They dont last as long, but are much cheaper and perfrom great. I don't like the champions that the later model 2.5s came with however.
Magnecore- did they fix that problem with the wires popping off over time on the 2.5l coilpack?
Old 06-15-2005, 03:40 PM   #8
10.5sec1992AWDtalon
Member#: 63681
Mine have stayed on well.
Old 06-15-2005, 05:25 PM   #9
Hawk296
Member#: 14555
1995 Impreza L
Baja
cool, good to know. DId you get them for a reasonable price?
SoCal: 04 wrx impreza wagon with 78k trades ok STI upgrade masters324 Private Vehicle 'For Sale' Classifieds 40 06-08-2010 12:58 AM
08+ wrx turbo upgrades? MNsuby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 06-07-2010 04:16 PM
Factory Sound Upgrade package upgrades philioWRXman Car Audio, Video & Security 1 03-19-2002 02:13 AM
Do I go factory upgrade or do sound upgrade myself? cwb124 Car Audio, Video & Security 18 02-23-2002 04:27 PM
Is it better to upgrade the pillow mount also if upgrade the struts and springs? V6 Brakes, Steering & Suspension 2 01-25-2001 11:22 AM
