Old 06-12-2005, 01:13 AM   #1
mike270
Member#: 12863
2002 2.5RS
Default Autometer Speedo Pod Questions
I just got around to installing my autometer 2 gauge bezel and ran into a few minor problems.
When I got the pod in I noticed that the back section is covering the top of my speedo. I can push the plastic up a bit so I can see everything fine but I am sure this won't stay like that since its not the plastics normal shape. Anyone else have this problem and have any suggestions?
Also, how exactly are those brackets supposed to work. Following the directions its impossible to mount the brackets to the gauge cluster. The screw is just too big. So I tried to turn it around so the bolt could actually fit through the hole. This worked until trying to put the screw through the pod when I realized that the two don't line up. I don't see any way that these could work with the bezel. It stays fine without it but I am going to be rallying my car so I want to make sure that everything is fastened solid.
Did I somehow possibly get the old version of the pod or is this just the way it goes with these?
mike270 is offline   Reply With Quote
Old 06-12-2005, 06:27 PM   #2
mike270
Member#: 12863
2002 2.5RS
Anyone?
Old 06-13-2005, 11:57 PM   #3
mike270
Member#: 12863
2002 2.5RS
Bueller?
Old 06-14-2005, 12:12 AM   #4
markadopolus
Member#: 69586
Bueller? Bueller?
markadopolus is offline   Reply With Quote
Old 06-15-2005, 12:35 AM   #5
mike270
Member#: 12863
2002 2.5RS
Ok, guess its just me then.
Old 06-15-2005, 12:55 AM   #6
hauvis
Member#: 50262
2000 Protege 90whp
I like Autometer Nexus gauges
hauvis is offline   Reply With Quote
Old 06-15-2005, 07:17 AM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
The old version of the pod did have issues with the center being too low - lots of people have posted problems with the brackets - many seem to leave them off.
Old 06-16-2005, 01:14 AM   #8
mike270
Member#: 12863
2002 2.5RS
Does anyone know how to tell which version of the pod I have? Are there any significant markings on it that would let me know? Maybe a little different visually?
I bought this pod new a few weeks ago but something tells me its the old version. Any ideas?
I'm not terribly worried about the brackets. I should be able to make something that will work easy enough. The rest of the fitment though makes me wonder.
Old 06-17-2005, 01:49 AM   #9
mike270
Member#: 12863
2002 2.5RS
Old 06-18-2005, 12:42 PM   #10
mike270
Member#: 12863
2002 2.5RS
Come on, someone has to know the visual differences between the two?
EDIT: Maybe someone knows if the instructions that come with it say Version 2 on them?
Old 06-18-2005, 01:16 PM   #11
knucklesplitter
Member#: 64246
I installed the brackets backwards from what the instructions say. The screws that attach the bezel to the brackets were very diificult to screw into the small pilot holes in the brackets, so used some 3-in-1 oil to help. Drilling them out a little might be better. My Omori gauges were so deep that I had to trim the brass studs and use nuts instead of the wingnuts to get the bezel to go on all the way. Other than that the install was a snap <rolling eyes>. No problems with the bezel covering the factory gauges.
knucklesplitter is offline   Reply With Quote
Old 06-21-2005, 01:56 AM   #12
mike270
Member#: 12863
2002 2.5RS
Thanks for the reply!
So I am thinking I have the old version. There has to be some visual differences or someway to tell the two versions apart. Anyone?
Old 12-26-2006, 01:11 AM   #13
XWRATED
Member#: 111454
2003 WRX Sedan
WRB, 86' Buick GN 500 HP
I just got one of these and on the top of it is a bunch of shave type lines across the top. Did anyone have this also? It doesnt look smooth across the top. I think Im gonna have to bring out the sandpaper.
Scott
XWRATED is offline   Reply With Quote
Old 12-27-2006, 04:37 PM   #14
WoodyWagon
Member#: 134744
2008 STI BBS Navi
Installed the AM pod in Sept. No problems with fit. didn't use brackets, just two top factory screws. Defi boost & oil temp.
WoodyWagon is offline   Reply With Quote
Autometer dash gauge pod question. niblick Interior & Exterior Modification 1 10-28-2007 05:04 PM
non-autometer 52mm gauges in autometer bezel pod? (which is 52.4mm or 2 1/16") shotoyan Interior & Exterior Modification 2 11-21-2005 06:53 PM
Autometer gauge pod fitment question (2005 STi) STiMUL8 Interior & Exterior Modification 4 01-01-2005 10:11 PM
autometer clock pod question??? gizmodude311 Interior & Exterior Modification 12 11-21-2004 10:30 AM
DEFI 52 mm D-Series Gauges in Autometer Speedo Cluster [$275 Shipped] killermike Private 'For Sale' Classifieds 12 09-04-2004 10:56 PM
