![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#126 |
Member#: 69900
#127 |
Member#: 37736
Vehicle:2003 WRX Race Wagon Silver |
Has anyone tried the heavy duty bearings that Vlad ordered? I have a 03 wagon/track car and need to replace the bearings and would like to try the HD bearings.
#128 |
Member#: 7958
Vehicle:09 GH B+ |
I've been keepng a pretty close eye and not to my knowledge- ofcourse someone could have and not posted, but that wouldn't be nice
#129 |
Member#: 37736
Wonder if Vlad would sell me the ones he bought?
#130 |
Member#: 46135
Vehicle:02 WRX Powered by Sti V9 Spec C |
Yes, I would. I can always buy another set and this will help everyone, because all (including me) want to know what happens if you install these. Let me go look for them. We'll just have to agree on a price, PM me.
#131 |
Member#: 46135
here is a pic
#132 |
Member#: 46135
![]() more info.. |
#133 |
Member#: 46135
![]() The whole kit |
#134 |
Member#: 13304
RMIC
Vehicle:2002 WRX WRB De Re Metallica |
Vlad: Can you post a close up of the bearing box (with part numbers/etc) please?
#135 |
Member#: 46135
last one..
#136 |
Member#: 37736
PM sent.
#137 |
Member#: 100708
Vehicle:2000 2.5RS 2006 WRX |
Just out of curiousity, what's the difference between those HD bearings and the OEM? I'm assuming someone took both of them apart and compared
#138 |
Member#: 6034
BAIC
Vehicle:2002 WRX It's Soo-BAH-roo |
4T-CRI-08A01 (OEM) Dynamic Load Rating of 75000 lb
4T-CRI-0823 ("HD") Dynamic Load Rating of 82500 lb See my post #46 on this thread. |
#139 |
Member#: 6459
SCIC
Vehicle:2008 LGT Spec-B stg4 Infamous Tuned 315/330 |
Why is it neccessary to tighten the axle nut when not on the ground? Did I read that right a few posts back?
#140 |
Member#: 19057
Vehicle:2002 WRX & Red Ford 1-ton Van |
Ok, Ive just been reading about comparitive life and the equations used to estimate the life of any particular bearing. There seems to be a way to substitute the different dynamic load and static load ratings into the maths to solve for f(lr)=life. The main thing is to understand that this would be an estimate based on several empirically (I'm guessing thats how NTN developed their life equations.) determined equations.
(No-one who works at NTN technical center (in A^2) drives a Subie? Thats rediculous, engineers generally like them.) Otherwise I'll try to use the brother hood of engineers to get some sort of answer. Here is my guess: 1 ) IFF (if only if) the two bearings are dimensionally exactly the same. 2 ) The increased dynamic and static load ratings will result in a longer life. Ha Ha! Eureka! See link: http://www.ntnamerica.com/Tech_Supplements/news10.htm By that little bit there I believe that the higer rated bearing will replace the OEM one. NTN# -0881 is Nissan Prt#: 4021-001-E00 NTN# -0823 is Nissan Prt#: 4021-016-E00 The guy at NTN Tech support said that the B/p he looked at were pretty much the same. I'm going to try -0823 and find out. So if no one has tried these bearings I'll be your Huckleberry. Last edited by LyveWRX; 04-12-2006 at 09:10 AM. |
#141 |
Member#: 7958
Vehicle:09 GH B+ |
longer+ sronger = better
Please let us know if they work. |
#142 |
Member#: 46135
Okiedude has mines, hopefully he'll have some info for us too, when he's ready to do the work.
#143 | |
Member#: 19057
NEWEST Update!!!!!~
From NTN engineers: Quote:
So on that note I am NOT going to be installing the -0823, I'm going to order the OEM from my local dealer. |
#144 |
Member#: 7958
Vehicle:09 GH B+ |
Well- that certainly changes the outlook on things- I assuming theya re very close- a couple of thousandths different?
#145 |
Member#: 19057
bigsky- yea thats my estimation also.
The trouble is that I am not a bearing designer, I cannot even conceptualize how I would measure endplay clearance. And I dont have both infront of me. I do know that thousandths can be really big when talking bearings. |
#146 |
Member#: 46135
I just found an article describing endplay and the clearance associated.
If i ws to venture a guess, it could be that when applying the proper tightening force, after everything is installed, instead of a normal axial play of x, you'll have an x + 0.0 etc So if you were to take a dial gauge and look for the Subaru proper play you won't find it. however, since that bearing was DESIGNED to run that clearance, it will run that clearance. Possibly, a good thing to know would be the proper tightening torque for the bearings. That could be found easily, if we knew which Nissan it was. Just my afternoon theory.. link Last edited by Vlad; 04-12-2006 at 05:28 PM. |
#147 |
Member#: 19057
vlad- reading that article IMHO the endplay on the two row bearings that our cars use is set by the ground width of the inner races (cones) since the axle nut seems to tighten on those and tightens them into a flange on the spindle. (of course this is going by the diagrams and pictures. In that case it would not be possible to adjust the endplay by too much just with torque alone.
#148 |
Member#: 46135
I was thinking that proper torque has to be the one pertaining to the bearing, I realize it would not really be an adjustment.
If it's a Nissan-specified bearing, it would probably have to be torqued properly per Nissan, even if installed on a Subaru. I would like to have more info about how the endplay clearance would affect the bearing life, or maybe the warning refers to how the bearing would affect other components. I was just thinking that maybe the endplay clearance is a function of the dynamic load rating (due to heat generation by example)? But if our cars are lighter and therefore develop less heat in the bearing and therefore need less endplay clearance and also less dynamic load specified, unless if you drive them hard enough, then the situation changes.. Last edited by Vlad; 04-12-2006 at 11:28 PM. |
#149 | |
Member#: 19057
I noticed when I took one bearing apart last night that the cage is a plastic in the OEM, if there is a brass or steel cage in the nissan that might account for both changes, endplay and weight. (Dang where is the mechanical engineer when you need them, I can tell you what to make things out of, and how to heat treat them, and analyze them when they break. But no chance in bearing design.) |
#150 | |
Member#: 61132
Vehicle:2004 STi Silver |
Well, interesting to read this! The NTN technical support person you quoted asked me (NTN Design Engineer) about your question. I guess that makes me the "Conehead Racer". OK, so I do own an STi and have been to more than a couple autocrosses. I read through some of the long list of posts here. I'll look into the real differences in the various T/U hubs we make of this same physical size. Chances are I will need to do this myself someday. |
| Thread Tools | |
| Display Modes | |
| Rear Wheel Bearing Replacement Walkthrough, with pics | motohippy | Brakes, Steering & Suspension | 127 | 05-11-2013 04:07 PM |
| To those who've had wheel bearings replaced | SubEd | New England Impreza Club Forum -- NESIC | 9 | 01-01-2002 02:37 PM |
| Wheel bearing replacement? | rhdude | Mid Atlantic Impreza Club -- MAIC | 2 | 10-10-2001 04:27 PM |
| DIY Wheel Bearing Replacement? | mav1c | Brakes, Steering & Suspension | 1 | 10-02-2001 10:13 PM |
| Wheel Bearing Replacement? | LUME | Brakes, Steering & Suspension | 2 | 09-18-2001 04:57 PM |
