Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 06-12-2005, 11:40 AM   #1
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
Default Metallic Rattle?
I've noticed a metallic noise in my engine (possibly transmission?), but only while accelerating or cruising from 2000-2500rpm, but not at any other rpm. It's comparable to dragging a short length of chain under the front of the car, but fainter. My first though was burnt valves as my borla header broke a while back and has been leaking off and on (been repaired multiple times), but would burnt valves just make noise at the certain RPM range??? Anyone have any ideas what it could be?
BTW, it's a 1998 EJ22 with the 4EAT. Mods are GPMoto Short Ram, Borla Header, 2.25" exhaust with high flow cat and a universal muffler. Tranny fluid was changed (NOT FLUSHED) around 10k ago. Any help is appriciated.
Perdue is offline   Reply With Quote
Old 06-12-2005, 12:30 PM   #2
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Burnt valves? Whatever put that idea in your head? When you burn a valve, it either warps or develops a hole in the edge. The engine won't run real well at any time.
I suspect that your exhaust is either broken again or one of your heat shields is loose.
OneOBS is offline   Reply With Quote
Old 06-12-2005, 12:34 PM   #3
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
yeah, it is something else. If it happens at certain rpm range, it is a loose item that is being shaken at its resonant frequency. It is like a woofer, playing the certain frequency note it is best at playing, the sweet spot so to speak. Certain frequencies will affect certain things differently due to their mass, shape, etc... pull and tap on items like the exhaust, hangers, heat shields, and other metal to metal items. check for broken tabs, loose screws, etc...
janikphoto is offline   Reply With Quote
Old 06-12-2005, 12:35 PM   #4
janikphoto
Member#: 10471
2000 BMW Z3
Or, it could be a small hamster with a hammer, and everytimme you go too fast, he starts smacking things inside your engine compartment. Hamsters can be very tempermental...
Old 06-12-2005, 12:36 PM   #5
Nicklbrso
Member#: 44887
00 GC6
Could either be a loose heat shield or most likely the connection between the borla and the cat. Its very common with the borla header and stock cat to make a rattling noise. My old L does the same thing.
Nicklbrso is offline   Reply With Quote
Old 06-12-2005, 12:44 PM   #6
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
ROFLMFAO alrighty then
I was told that a leak so close to the heads could cause burnt valves, but I spoke with an ex-mechanic from my fire station on the phone and he said it doesn't sound like burnt valves to him, if anything to do with the engine. He told me burnt valves shouldn't really make any noise, but will cause misfires and lack of power instead. He said he's thinking one of the header pipes may have come loose inside the collector (it's wrapped with some leak patch stuff) and may be rattling due to resonance. I guess I'll stop worrying about it.
Thanks gain guys, and thanks for the laugh, janik.
Metal rattling sound after downpipe installation Bart's Impreza World Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 05-10-2014 07:32 PM
DP metallic rattle? enewtabie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-08-2004 09:39 PM
Metallic rattle from rear drivers side?? jroberts Service & Maintenance 4 07-28-2003 02:28 PM
Metal Rattle Noise Valdar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-10-2002 08:50 PM
('93-'01) Heat shield and other metallic rattles anyone?? RacerinLSL Impreza Forum 5 07-28-2001 04:26 PM
