#1 |
Member#: 50430
TXIC
Vehicle:2002 WRX EJ257/205 PSM |
Ok, I've got Morettes on my '02 WRX and I'm looking for an HID kit in the ~$350 range (preferably not more) that are in the 5000k to 5300k area. I've posted this in HID forums and all I get is "retrofit, retrofit, OEM". Blah, too bad. Can't retrofit Morettes and my electrical skills are zero anyways so any bulb modifications on my part are out of the question. I've heard McColloughs suck and that's what I'd been looking at, so again I ask, what would you recommend?
#2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Well you COULD retrofit the Morettes with proper HID projector units in place of the existing low beams. It would be pricey though, true HID modules aren't cheap. As the next best thing, for the $ you mentioned you can install genuine OEM type HID bulbs and ballasts in the H7 housings, no "kit" is needed.
Read the HID FAQ up top, the info is in there. |
#3 |
Member#: 63292
South East
Vehicle:2000 Subaru 2.5RS 2002 WRX powered |
edit: DELETED
#4 |
Member#: 57966
Vehicle:2002 wrx Sedona Red 11.59@124, best trap 131 |
The ones i have, have hella ballasts and they work great. I've had them for about 1.7 years now.
#5 |
Member#: 73008
NESIC
ive had a McCulloch 8000k 9007 kit for about a year now, love em. very bright, not much glare at all and very level beam down the road. the kit was $290 shipped from ebay.
#6 |
Member#: 63802
Vehicle:2002 PSM WRX Stage 2 2000 Black Trans am WS6 |
Phillips!
EDIT: Sorry, didnt see your price range ![]() Last edited by SubWRX2002; 06-13-2005 at 11:21 PM. |
#7 | |
Member#: 50430
TXIC
I read the FAQ and didnt see anything about that. |
#8 |
Trust no one
In this post-
http://forums.nasioc.com/forums/show...23&postcount=3 |
#9 |
Member#: 86968
South East
Vehicle:02 WRX / 05 350Z '11 335d |
#10 |
Member#: 33410
Vehicle:08 wrx dgm |
these
http://www.hidplanet.com/H72D2.html plus these http://www.hidplanet.com/ballasts.html <-- look at the second ooption with bulbs = done. clean cut off, proper heat range and excellent visibility. I should I know, I did the exact thing in my morrettes, wiring is easy. Find the positive lead off the low beam bulbs on the morette harness (use a multimeter), use that to trigger a relay (but ground the trigger). The power side of the relay is connected to a fused line to the battery and to the positive of the ballast, then ground the ballast to chasis or battery negative. mspain style diagram available upon request. |
#11 |
Member#: 63292
South East
could you send me that diagram? Kakarot256@hotmail.com
#12 |
Member#: 33410
let me double check a wire color on my car after work and i'll post one tonight.
#13 |
Member#: 63292
South East
i have a wire thats somewhat metled from the radiator, the one that crosses the car from driver side hl to the passenger side, should i change that for HIDs as theres going to be more current running through? what type of wire would i need as well?
#14 |
Member#: 50430
TXIC
Can I get a diagram too so I can show whoever will put my stuff in?
#15 |
Member#: 55915
South East
Vehicle:04 WRX stage 1/2 Wr blue pearl |
I have 6000k, got mine off of ebay. I think they are supervision. very nice, nice out put and bright. but I have them in h1, but I think they have them for h7. also they were $300 shipped.
#16 |
Member#: 33410
sorry it took me so long.
Ok so what you need is: 2 20amp inline fuse holders 2 20+ amp relays bunch of wire, medium gauge, nothing flakey your two ballasts. your two hid buls two H7 adapters. you can find them in my post above. the basic wiring looks like this you want the grey wire off the morette low beam to trigger the relay. ground it to chasis or battery, i think i had a problem with high beams when i wired it back to the yellow from the low beam. In this wiring, the power for the ballasts runs off the batt and you won't have to worry about frying any stock wiring. Good luck and pm me if you need any other help |
#17 |
Member#: 63292
South East
what do the numbers on the relay stand for?
#18 |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! '95 Montego Miata |
Those are the standard terminal numbers for Bosch-type relays.
#19 |
Member#: 75931
SCIC
Vehicle:2005 hmmm STI? Clark Tuned! |
i can get a Mcculloch HID Full set up for 300..Includes everything plus one year warranty on the ballasts and 6 months on the bulbs...just throwing it out there...by the way i am running 6000k on my 05 and they are nice..
#20 | |
Member#: 22303
SCIC
Vehicle:2002 WRX Wagon WRB 2006 W211 e55 AMG White |
j/kThanks, I needed this too. Clavo |
#21 |
Member#: 33410
^^ done with a tablet PC
#22 |
Member#: 68010
Vehicle:2004 WRX w/ Cobb 2.5 WRB |
I'm never going with Mcculloch ever again the ballasts don't last long. I've used a philips kit which lasted me almost 3years till I sold my car (still functional) I just bought another philips kit (w/o the brand sticker) for 200bucks shipped off of ebay, installed today and it's bad a$$. Hellas are good too. HID's are night and day compared to standard halogens.
#23 |
Member#: 58477
Vehicle:. Member #1 of the witty MS Crew |
i would never go mcculloch either. but i also wouldnt buy an hid kit if im not properly retrofitting them.
#24 |
Member#: 26607
Vehicle:2002 wrx wagon |
im using the mcculloch 5k w/ clear bulbs in my projectors right now. It works good and only cost 280 shipped off ebay, but if I were to do it all over again I might consider getting a proper set with hella ballasts and rebased philips bulbs.
Or at least the bulbs because I feel the ones that came with my kit just arent as bright as oem setups..especially the german cars. the problem is those kits cost 500+ |
| Thread Tools | |
| Display Modes | |
| What code reader would you recommend? | weaC sauCe | Engine Management & Tuning | 6 | 02-04-2006 01:31 AM |
| ('93-'01) What tools would you recommend for an Impreza owner? | akm3 | Impreza Forum | 3 | 09-27-2003 06:51 AM |
| Coming up on 20k. What would you recommend be maintenanced. | thrdeye | Service & Maintenance | 1 | 08-06-2003 07:05 PM |
| What mbc would you recommend? | Impreza01 | Factory 2.0L Turbo Powertrain | 3 | 05-04-2003 10:39 AM |
| what tire size would you recommend? | nick25RS | Brakes, Steering & Suspension | 4 | 11-18-2002 10:23 PM |
