Old 06-13-2005, 06:55 PM   #1
Mechkiller31st
Member#: 38474
1998 Impreza Wagon L
Brilliant Red
Default Perrin Pulley Problem
Well I have had this Perrin Lightweight Crank Pulley for about 6 months now and it has been sitting outside my engine bay becasue i was having problems getting it installed. Well 2 weeks back I was able to finally get it in but found a problem. the woodruff key thingy seems to be just a bit wider then what was notched into the pulley. I dont know if i should send it back to RalliTek and tell them or just get the notch widened a smug. has anyone else had this problem. I have a 1998 L 2.2L wagon.
Mechkiller31st is offline   Reply With Quote
Old 06-13-2005, 07:28 PM   #2
Nicklbrso
Member#: 44887
00 GC6
Never had this problem with an Unorthodox or Mr. Josh pulley. You sure you're just not lining it up right? If it doesnt fit I would send it back. Not worth trying to make the key bigger as you may screw it up and rallitek wont replace it.
Nicklbrso is offline   Reply With Quote
Old 06-13-2005, 11:33 PM   #3
punkrocksailor
Member#: 43376
It shouldn't be any different unless your key is damaged. Subaru has used the same pulley size since 1993 (maybe even before then but I don't pay attention to those cars). You may need to clean the key off and maybe file it a little.
Cheers,
Joel
punkrocksailor is offline   Reply With Quote
Old 06-14-2005, 10:40 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Hold it up to the stock one and look through it. Align the key ways and see what the problem is. If the key way is too narrow then send it back. If the woodruff key hammerred the slot bigger in the stock one then you may need to replace the woodruff key.
Sometimes during removal the woodruff key will tilt in it's slot. It is a crescent shaped key way. It may need to be tapped in and straightened. I would not file it, but I have rubbed them on 600-800 grit sandpaper on a flat surface to clean them up a bit.
Good luck.
Tim Sanderson is offline   Reply With Quote
Old 06-14-2005, 11:07 PM   #5
Mechkiller31st
Member#: 38474
Brilliant Red
Thank you everyone. I was thinking of getting a woodruff key anyways and see if it fits if it doesnt i would just resize it on the pulley i think it wouldnt affect anything.
Anybody have problems with Perrin Pulley? scoooby03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-14-2006 01:31 PM
installed Perrin pulley problem alster Car Part Reviews 5 02-12-2004 03:44 AM
Perrin Crank Pulley problems Kitt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 01-13-2004 12:42 PM
pulley problem I think, stock pulley Eaglesfan2422 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-25-2003 11:48 PM
Perrin crank pulley problem WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-03-2002 12:02 AM
