Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 06-13-2005, 11:06 PM   #1
Predator3
Member#: 50161
'05 WRX stage 2
San Remo Red
Default stage 2 target boost?
I just got my upipe and downpipe installed today and i programmed my AP stg2 map and in 2nd and 3rd gear i hit 14.1 and in 4th i hit 14.4 and 5th i hit 14.8.
Aren't these numbers a little low? Is it because it's only my first day being stage 2 and it needs to adapt? What should my target boost be?
Thanks
Predator3 is offline   Reply With Quote
Old 06-13-2005, 11:23 PM   #2
WRX-CBR
Member#: 82197
03 WRX
Usually yes. About 100 miles or so. I know someone else on here had the same problem. Maybe he can help.
WRX-CBR is offline   Reply With Quote
Old 06-13-2005, 11:27 PM   #3
quadzilla
Member#: 84262
03 little bit jdm,
little bit usdm, all fun
Have you tried the vishu reset? Everytime I reflash the ecu I do the vishnu reset and my AP programs perform EXACTLY the way cobb says they should. 16.5 is target.
quadzilla is offline   Reply With Quote
Old 06-14-2005, 01:26 AM   #4
willguidry
Member#: 16388
Predator....I see you are running the 05 WRX. Spoke with Cobb, and they said alot of the 05 WRX's wastegate pre-tension is what is limiting them from reaching target boost.
See this thread I started.
http://forums.nasioc.com/forums/showthread.php?t=781443
Sounds to me your having the same issue. Don't bang your head. Pull the heatshield, mark the wasgate arm nut and arm with a sharpie, then make two full rotations shortening the arm.
That put me around 15.8PSI.
I'll probably give it another half turn or full turn to make it a full 3 x 360 turns.
Let me know if you need anymore help!
willguidry is offline   Reply With Quote
Old 06-14-2005, 02:57 AM   #5
Predator3
Member#: 50161
'05 WRX stage 2
San Remo Red
so do u guys think that i should do the vishnu reset first? And if doesn't reach target boost i should try adjusting the wastegate arm?
Thanks a lot for the responses.
Old 06-14-2005, 03:07 AM   #6
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
give your ecu about a week or so. if you're still not hittin target boost try the wastegate arm adjustment or the hwg map at your own risk.....
Bishop is offline   Reply With Quote
Old 06-14-2005, 10:26 AM   #7
WRXXXual
Member#: 67784
Now with 100% more
STI short block!
Been having the same trouble, except, I've only seen 13.5 psi... and that was only peaking for a second.
I know I don't have a fully open turbo back exhaust; in fact I still am stock from the 3rd cat. back, but there has to be something I can do.
I don't want to get a new cat. back exhaust system because I really want an electronic cut-out. In the mean time, is there anything I can do to hit target boost?
WRXXXual is offline   Reply With Quote
Old 06-14-2005, 10:35 AM   #8
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
Assuming you're running AP Stage II, you could give the alternative Stage II map a try. They're made for people just like you that have trouble hitting target boost.
On a side note, I am always curious why some cars have trouble reaching the target level while others experience no such problems. I have a hard time believing that manufacturing tolerances produce such a wide range of behavior. Was the car always under target boost even from factory?
Ziggyrama is offline   Reply With Quote
Old 06-14-2005, 11:23 AM   #9
WRXXXual
Member#: 67784
Now with 100% more
STI short block!
Ziggyrama thanks for your response
To answer you last question: I don't know.
I am running a QTP equal length header with an integrated UPpipe, and a bosal Div. wastegate DOWNpipe.
Also, I'm currently using the ver 1.3 93 octane stage two map.
are there any ill affects of using the HWG 93 octane stage II map?
Old 06-14-2005, 11:44 AM   #10
willguidry
Member#: 16388
Well....I really think since the stock PSI is 13.5, it would make sense for the factory to have the wastegate arm adjusted to that pre-load to prevent spikes etc.
I'd download the HWG stage 2 map first....try that out. I know it's going to be your wastegate pre-load...but better be safe than sorry.
PLEASE. monitor your boost with the AP CAREFULLY. If for some reason, it's NOT your pre-load....you can and WILL boost over 17 to 18PSI and up.
So drive cautiously..watching the PSI as you push the car. If you go over 16PSI stop.
If not, and your still hitting the same numbers +/- .5 then it's your wastegate.
Adjust, and be happy.
Again, let me know if I can help you out anymore.
Old 06-14-2005, 11:44 AM   #11
Ziggyrama
Member#: 53665
2012 Tribeca Ltd.
By the way, how are you reading the boost? Using AP or some other device?
Old 06-14-2005, 11:47 AM   #12
willguidry
Member#: 16388
Oh also....make sure you put the Stage 2 mapping back on your car removing the HWG map before you go test drive the wastegate changes you made.
If not, it will have no limit set by the ECU and boost until the wastegate dumps it. Which, if you shortened the arm by too much, could be 18-19PSI...
And that is no good. Well..
Old 06-14-2005, 11:55 AM   #13
WRXXXual
Member#: 67784
Now with 100% more
STI short block!
I'm most deff. using the live boost reading from the AP. I'm not stupid enough to trust the factory boost gauge!
I installed the AP last Friday morning, and I figured I should start seeing 16.5 +/- .5 psi by now That not withstanding, I have noticed a HUGE difference in the car already, and I can't wait to get it to target boost!
Thanks for the advice gentlemen, I will certainly use it.
Old 06-14-2005, 12:22 PM   #14
spacenut999
Member#: 40307
2004 WRX Sport Wagon
Target boost for stage II 93 Oct is 15.8 +/-.5
spacenut999 is offline   Reply With Quote
Old 06-14-2005, 03:12 PM   #15
Predator3
Member#: 50161
'05 WRX stage 2
San Remo Red
i turned the arm 2 times and im at 14.0 in 2nd and 14.4 in 3rd, does this sound right? Is the 15.8 target for all gears?
Old 06-14-2005, 03:45 PM   #16
mistaare
Member#: 50439
04 wrx stg 2
why is the HWG map "use at your own risk?"
mistaare is offline   Reply With Quote
Old 06-14-2005, 03:45 PM   #17
willguidry
Member#: 16388
No. for 4th and 5th
what did you hit for those?
Old 06-14-2005, 03:45 PM   #18
willguidry
Member#: 16388
Because that map tells the ECU to run boost as high as the wastegate will hold.
Old 06-14-2005, 03:51 PM   #19
Predator3
Member#: 50161
'05 WRX stage 2
San Remo Red
OK i my wastegate arm is turned at 3X360 turns in and in 2nd i'm at 14.4, 3rd at 14.8, 4th at 15.2 and 5th at 15.3 with a spike at 15.6
Should i do another half turn (180)?
Thanks
BTW i did the vishnu reset after every time i changed the wastegate arm legnth
Old 06-14-2005, 03:55 PM   #20
willguidry
Member#: 16388
Hmmm Just keep dialing in till you hit target boost. I mean...your right there.
Do one more turn and post your findings.
You are doing this with the Stage 2 map right? Not the HWG map...
Old 06-14-2005, 03:59 PM   #21
WRXXXual
Member#: 67784
Now with 100% more
STI short block!
Thank you for answering that!
Old 06-14-2005, 04:11 PM   #22
Predator3
Member#: 50161
'05 WRX stage 2
San Remo Red
yea i'm doing it with the Stage 2 map, If i did the HWG i would have put it back to normal.
Old 06-14-2005, 04:11 PM   #23
willguidry
Member#: 16388
And?
Are you hitting target?
Old 06-14-2005, 04:18 PM   #24
Predator3
Member#: 50161
'05 WRX stage 2
San Remo Red
BTW what do you guys read in 2nd and 3rd gears?
Old 06-14-2005, 04:25 PM   #25
willguidry
Member#: 16388
Depends...anywhere from high 12's to low 14's (3rd)....but mine is still tweaked.
I need to get back in there and do another "adjustment"
Not Hitting stage 2 target boost 06stisilver AccessPort 6 05-27-2008 09:44 PM
stage 2 target boost? smr_wrx AccessPort 2 03-18-2007 02:19 PM
stage 1 target boost ? hocman99 AccessPort 1 07-28-2006 11:58 AM
Cobb stage 2 target boost Soob02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-16-2005 02:31 PM
Cobb stage 2 target boost question MO REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-27-2004 03:59 PM
