Old 06-14-2005, 12:29 PM   #1
Space
Member#: 75799
Default How to remove the Green film behind the odometer
Hi does anybody here know how to remove the green film behind the odometer??
(I have already removed the green film behind the dial and was stuck on this odometer)
Really need your help
Thanks
Space is offline   Reply With Quote
Old 06-14-2005, 12:57 PM   #2
pityr
Member#: 31719
sand paper...
check out the sticky about changing the gauge's color or follow this link
http://forums.nasioc.com/forums/showthread.php?t=690378
pityr is offline   Reply With Quote
Old 06-14-2005, 01:29 PM   #3
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
yeap scratch it off, its a PITA!
i dont recommend it because it makes the black areas of the cluster look gray
Impreza2003 is offline   Reply With Quote
Old 06-15-2005, 01:48 AM   #4
Space
Member#: 75799
Thanks for your info ....
Old 06-15-2005, 02:01 AM   #5
Space
Member#: 75799
Hi pityr Thanks for your info.....
I had already sand off those green film behind the dial and left only odometer(the digital meter that show the distance you travel).I did do a search and not much info on this.
So need help on this.
Thanks.
Old 06-15-2005, 02:02 AM   #6
Handsdown
Member#: 29355
can you reverse polarity so that the background is black and the numbers are green? cuz that's what i'd do if i knew how. i know kids back in high school were doing it to their watches... isn't there a film you can just flip over?
Handsdown is offline   Reply With Quote
Old 06-15-2005, 02:24 AM   #7
Space
Member#: 75799
I did take a look on the LCD screen.Seem like cannot be done cause the film is in between two piece of glass.
Old 06-15-2005, 02:35 AM   #8
Handsdown
Member#: 29355
the glass cannot be flipped as well?
Old 06-15-2005, 02:38 AM   #9
Handsdown
Member#: 29355
http://en.wikipedia.org/wiki/Image:LCD_layers.png
it looks like it's layer 5 in the above diagram that must be flipped. can you take a picture of the ODO display out of the cluster?
Old 06-15-2005, 03:09 AM   #10
Space
Member#: 75799
I lift up with a picer seem like all of the layer are stick together.
I will try to remove the green film again this coming weekend and will take a pic for you...
Old 06-15-2005, 10:53 PM   #11
Handsdown
Member#: 29355
sweet man i'll check back.
Old 06-17-2005, 11:12 PM   #12
Space
Member#: 75799
Any expert to reply ??
Thanks
Old 06-17-2005, 11:27 PM   #13
Sanchez
Member#: 51002
2005 Pig STi
Turbo Negro
I just did it yesterday. BE VERY CAREFUL!!!!!!!!!!!!!!!!! My tach is now 1k off in the high end and I can't find ANYWHERE to get it recalibrated.....
Sanchez is offline   Reply With Quote
Old 06-18-2005, 01:37 PM   #14
Space
Member#: 75799
SaNChEz sorry to hear that.Btw how u removed the green film??
Old 06-28-2005, 03:38 PM   #15
onyx445
Member#: 84173
2001 Impreza WRX STI
Default odometer color change
Back when i had a focus i did this and it worked i dont know if it will work for our subies. but its worth a try.
.jwardell.com/focus/guageslcd.html
Just add the www. because i have under 10 posts. what can i say i have only had the car for 2 weeks.
onyx445 is offline   Reply With Quote
How to remove Rockblocker film off headlights? just_a_wrx Mid West Subaru Owners Club Forum -- MWSOC 7 02-07-2007 12:36 AM
How to remove those black spots on the inside of the rim? iNfEk Tire & Wheel 11 08-25-2005 10:09 PM
Anyone know how to remove the "subaru impreza" decal on the rs foglamp covers? WR-REX Interior & Exterior Modification 3 11-10-2002 11:12 PM
how to remove the interior trims on the RS? STi - IMPREZA Newbies & FAQs 0 07-04-2001 06:29 AM
how to remove the orange things under the turn signals Supapooh Interior & Exterior Modification 9 02-28-2001 03:35 PM
