Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-14-2005, 01:47 PM   #1
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Default Hydra PWM; DCCD tie in?
So, elsewhere I published a thread where I made my own rudimentary DCCD controller. When time allows, I mean to increase its usefulness with things like throttle, brake, and handbrake tie ins.
As a recent Hydra owner (not yet installed) I'm curious about the PWM outputs. Specifically, the 3D maps. Anyone know what the PWM outputs actually look like? Frequency, amplitude, duty cycle, polarity etc? I'm just wondering if I could use a 3D map with say throttle % and road speed to output a variable waveform that could be used to control a JFET driver to run the DCCD coil?
I would still need basic diode protected signals from the handbrake and brake pedal to turn off the signal, but it would be nice to have some logic control for a variable "lock" control.
Am I dreaming, or could this work?
fragment is offline   Reply With Quote
Old 06-14-2005, 07:04 PM   #2
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
It should be possible
The Hydra can output Pulse Width Modulated square-wave signals.... then all you need is a controller to receive and send a signal to the DCCD switch - just some type of "multiple position" switch depending on the PWM output - If you have some EE or electronics background- that should be piece of cake !
If you get it to work - make sure you post your schematics / circuit diagrams !!
Phil is working on an Aquamist Water Injection controller - so YES the Hydra is capable of sending signals to almost any type of controller
Call Phil @ Element Tuning or Andrew @ HydraEMS USA to get definite answers - or just use your Oscilloscope to see the outputs
http://www.hydraems.com/america/
Auxiliary outputs:
PWM 1 - 4, 9 - 14 and 16 are general purpose switch to ground 1A current limited outputs. PWM 1 - 4 have optional free-wheeling diodes for linear control of variable solenoids. PWM 5,6 and 8 are general purpose switch to power 1A current limited outputs. All PWM channels have 33V flyback limiting. PWM 1 is not available for DBW Cars. PWM 7 and PWM 15 are currently not available.
engineerx is offline   Reply With Quote
Old 06-14-2005, 08:27 PM   #3
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Well, I do have an electronics background, but its been underused for years and I have discovered serious corrosion
I don't know if I could bias a transistor if you put a gun to my head...
That said, I'm not afraid of getting my hands dirty with flux
Election tie in Nevada Jersey-Girl Off-Topic 1 11-08-2004 01:29 AM
Poll: Bush, Kerry tie in 2nd debate Buddha Pest Political Playground 0 10-09-2004 11:30 AM
Registration Renewal/Recall tie in TheMadScientist New England Impreza Club Forum -- NESIC 4 10-05-2004 08:12 PM
Do u tie in while in the back seat? Keith Off-Topic 31 12-19-2002 06:40 PM
A-pillar tie-in plate? narcotix Motorsports 0 03-01-2002 09:14 PM
