Old 06-14-2005, 04:12 PM   #1
fizzak
Member#: 84968
2005 WRX
Default Rim size specs= 17x7 what does the 7 mean?
Does it indicate the width of the rim? If so what tire width can be used on a 17x7. 245's???
fizzak is offline   Reply With Quote
Old 06-14-2005, 04:13 PM   #2
hauvis
Member#: 50262
2000 Protege 90whp
the 7 is the width
hauvis is offline   Reply With Quote
Old 06-14-2005, 04:15 PM   #3
hauvis
Member#: 50262
2000 Protege 90whp
width as in tire size...the bigger that number is the wider tires you can fit...
Old 06-14-2005, 04:18 PM   #4
Spooled
Member#: 14958
1991 318is
I would put 215's on a 7in width.
Spooled is offline   Reply With Quote
Old 06-14-2005, 04:20 PM   #5
fizzak
Member#: 84968
2005 WRX
Stock 05 rim carries a 205 tire, so what # would that rim be?
Old 06-14-2005, 04:24 PM   #6
Spooled
Member#: 14958
1991 318is
The stock wheels are 16x6.5
Old 06-14-2005, 04:28 PM   #7
fizzak
Member#: 84968
2005 WRX
Awesome thanks, So how wide a rim could I go on a stock 05?
Old 06-14-2005, 04:53 PM   #8
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Stock rims(6.5") can handle some 225's, but are much better suited for 215's
17 x 7" rims are better suited for a 225, though you may be able to get some 235's.
The real issue is tire oversizing, going to big can actually hinder performance rather than help. My friend runs 225's on stock rims and the sidewalls have a lot of flex when swinging through turns.
Gfunk720 is offline   Reply With Quote
Old 06-15-2005, 06:48 AM   #9
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Safely you could go with a 8" wide wheel. Even an 8.5 would work. 9" would be pushing it and the tires you'd want to run would probably require fender rolling. A lot of people run 17x8 and 18x8 with up to 245 width tires. The biggest concern is offset. You want to keep it higher than +48 if you can.
What does the EJ mean with our engines Kevin Thomas Normally Aspirated Powertrain 33 03-14-2011 09:54 AM
What does the J mean 03 bug eye General Community 6 09-16-2007 09:17 PM
Stupid Question. A 17x7.5 with a ET48. What does the ET mean? 2.2gotboost Tire & Wheel 4 03-01-2004 04:14 AM
what does the sti mean to 2.5 NA motor owners? liigod STi Forum Archive 17 01-07-2003 07:53 AM
What does the rabbit mean? chyisan General Forum Archive 17 08-22-2000 12:01 AM
