Old 06-15-2005, 12:29 AM   #1
rainmanjam
Member#: 64581
2004 STI
Unhappy Converting Millivolts to Volts
I have a EGT Sensor that I am trying to hook up to my SBC-ID. Is there anything out there that will convert millivolts to volts so it can be read. Thanks in advance.
rainmanjam is offline   Reply With Quote
Old 06-15-2005, 02:52 PM   #2
aspitfire
Member#: 59916
2004 STi
well if its anything like meters and millimeters, "milli" is considered 1/1000 just going by general knowledge, dont know if volts work that way..
aspitfire is offline   Reply With Quote
Old 06-15-2005, 05:26 PM   #3
2phless
Member#: 69343
1998 TransAm cnvrtbl
You probably need to build an op-amp, amplifier and calibrate it to a thermocouple's voltage at known temperatures vs the desired input voltage range of your GReddy piece. Then program the greddy piece to output the recived voltage as a temperature.
There might be a pre-fab package that greddy sells that'd make your life a lot easier.
If you want to dabble. I'd figure out how to use an LM741 op amp, a K type thermocouple (yellow wire (+), red (-) ) and build a simple amplifier.
2phless is offline   Reply With Quote
Old 06-16-2005, 02:20 AM   #4
Moods
Member#: 71961
2003 WRX Sedan
MBP
I don't think it's possible to go from millivolts to volts...
http://www.nace.org/nace/content/edu...cp/basic_q.asp
*at the bottom - warning - learning experience*
Moods is offline   Reply With Quote
Old 06-16-2005, 02:42 AM   #5
rainmanjam
Member#: 64581
2004 STI
Lightbulb
Old 06-16-2005, 04:18 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Originally Posted by rainmanjam
nice find.
note: this could be used to integrate egts and the txs tuner pro
Old 06-16-2005, 10:51 PM   #7
2phless
Member#: 69343
Originally Posted by ride5000
nice find.
If you can find the plugs for the tuner-pro. I haven't, and I don't want to solder to their board. Anyone got a source for the little 2 and 4 prong txs plugs? I have access to a ton of various molex-knockoff plugs and even googling the hell out of them, I can't find something that'll fit the little TXS molex inputs and outputs.
That is a good find there. As long as the output is as linear (or not) as the input (and I'm sure it is) it'll work well. Too bad it's $40+ since it contains about $.50 of parts. Granted it has several minutes of R&D behind it and a little more time in production. Perhaps truely worth $20 for a water-tight and tested product. I need to actually break out the components and start building little things like this so I can help save forum members some money. I'm still pissed that I had to pay $14 for a resistor to fix a O2 sensor cel just to learn 1M ohm was the answer...
I wonder how many people here really thought you were looking for a conversion table on paper. If not some of the above need to practice 'not helping' in the newb section.
Old 06-17-2005, 02:38 AM   #8
rainmanjam
Member#: 64581
2004 STI
Unhappy
I thought that was weird myself. I can do a .5 second search on Google and find a conversion table out there. I really found it on eBay. I didn't have time to bid on it so the guy gave me a link to his web site.
Yea... if I had time, I would have tried to haggle him down in price..but in a pinch, value is directly proportional to need.
Old 06-17-2005, 07:41 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
molex plugs: look for old trashed p4 atx power supplies. the auxillary power connector to the mobo fits perfectly.
Chevy commits to Volt production scott_gunn Non-Subaru News & Rumors 10 05-14-2007 11:05 PM
Company that converts paper to doc to electronic svxr8dr Off-Topic 3 12-10-2003 11:49 AM
Fastest way to convert DIVX to VCD or SVCD? aod Off-Topic 8 10-08-2003 01:18 AM
Free program to convert mp3 to midi?? xtheviperx Off-Topic 20 07-07-2003 07:32 PM
Is it possible to convert 93 to 2000 body? RotarFreak Interior & Exterior Modification 7 07-12-2002 01:06 AM
