Old 06-15-2005, 08:30 AM   #1
kf6gpy
Member#: 89254
2007 Wrx sti
Rally blue
Cool autometer oil temperature reading problem
I have 2005 wrx sti,I currently installed oil temperature gauge(autometer/it has 300 degree maximum read) the problem is when it gets hot(normal daily driving)it stays maximum 300 degree, my installation mechanic says exhaust manifold are so close to the oil filter and oilfan area it trasfer the heat from there that is why,is any body know what is normal gauge temperature(is it normal to go over 300 degree),he did put some heat wrap around the sensor to block the heat but it did not work at all, and I could not find the gauge(auto meter one) it goes over 300 degrees,only one available one is oil tank temperature guage(atm-4346/autometer),is anybody help me out on this one? thanks!
kf6gpy is offline   Reply With Quote
N/A oil temperature readings Patrick Olsen Normally Aspirated Powertrain 25 07-12-2007 07:14 PM
Autometer oil temp gauge problem :( gregor2001 Interior & Exterior Modification 0 04-14-2007 11:53 PM
What are your oil pressure and temperature readings, what do you like to see? 02R6 Built Motor Discussion 4 10-23-2006 07:10 PM
Autometer Oil Pressure guage reading high? Scuter83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-04-2005 09:55 PM
Autometer Oil Pressure Guage reading weird Scuter83 Electrical & Lighting 1 01-04-2005 08:17 PM
