Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 06-15-2005, 11:07 AM   #1
djruslan
Member#: 82133
2010 STI SE
Default WRX 2.0L Stage 2 Xede
Hello,
I have some questions regarding the Vishnu Xede Stage 2 for WRX.
My setup is a Vishnu Xede, VF30, STi Pinks, 255l/h Walbro, 3" turbo back no cats, stock uppipe gutted, K&N drop in filter, and intake silencer removed. All other parts are stock.
To be honest I don't seem to notice that much power gains from Stage1 w/stock turbo.
Ok, here is the story I raced my friend streight line he was driving E36 M3 stock, and I pulled away from him, I mean like in 3rd gear he had no chance. This was when my car was running stage 1 w/stock turbo. Now he got his M3 reflashed installed an exhaust, and intake. Thats great but I installed a vf30 turbo, bigger fuel pump and sti pinks and uploaded stage 2 base map to my Xede. I should be able to pull away from him no problem right? WRONG he beat me. What da ****.
I'm convinced that the stage 2 base map is crap and needs to get tunned. I should be getting like 260~280 WHP and it shure doesn't feel like it. Does any one have a tunned map for the WRX with Xede with a similar setup that they can email me so I can compare it to what I have. I would hate to spend $400 on dyno session that will give me almost the same boost fuel timming paremeters that I currently have. I even tried raising the boost to 17psi not much difference from 14psi I just know that there is more to this.
djruslan is offline   Reply With Quote
Old 06-15-2005, 11:44 AM   #2
pezman04wrx
Member#: 66558
M3's are nuts ... I'm surprised you were able to pull on him the first time, really ... They can make some serious power, and likely with his reflash and exhaust work, probably is making real good power ...
pezman04wrx is offline   Reply With Quote
Old 06-15-2005, 01:11 PM   #3
djruslan
Member#: 82133
2010 STI SE
Yeh, but my WRX should have like 260~280 WHP M3 can't possibly make that power with just a reflash and exhaust. I need to see someone’s tuned Stage2 Xede map there must be something up with the base map from Vishnu. It's probably really rich on fuel and is not running the appropriate boost level. Xede Stage 2 is supposedly the equivalent of UTEC Stage 4. And that map runs 18psi for boost.
Old 06-15-2005, 02:53 PM   #4
djruslan
Member#: 82133
2010 STI SE
Should I assume that no one in this forum has an Xede with Stage 2 tuned to email me?
Old 06-15-2005, 03:37 PM   #5
x99percent
Member#: 27108
2004 STi
2004 A4
Have you verified that you're running the proper amount of boost?
x99percent is offline   Reply With Quote
Old 06-15-2005, 04:24 PM   #6
djruslan
Member#: 82133
2010 STI SE
Well I'm running 17psi, and don't want to go pass that without a Wideband hooked up. This Saturday I'll have it hooked up and I'll try running 19psi if my A/F is ok and see what it feels like.
Old 06-15-2005, 05:48 PM   #7
finger123
Member#: 42594
04 STI
black on Black wheels
i raced a 2003 M3 that was modified with a Dinan stage II. With my car running my stock map, he pulls on me in 3rd gear and on. With using my performance map, i'll pull on him all the way about 2 car lengths.
my mods are:
Txs TBE
UTEC tuned by clark
blitz intake
worx bov
finger123 is offline   Reply With Quote
Old 06-16-2005, 08:18 AM   #8
x99percent
Member#: 27108
2004 STi
2004 A4
What fuel are you running?
Perhaps the ECU has "learned" to retard the timing from previous WOT runs before you loaded the stage 2 map...? Resetting the ECU can't hurt.
Old 06-16-2005, 09:58 AM   #9
djruslan
Member#: 82133
2010 STI SE
Already did that and I'm running 93Oct. I just wish someone here had a tuned stage 2 map for the XEDE.
Load and Timing on 2.0L stage 2 WRXs... what you seeing? benw Open Source Reflashes 16 01-17-2008 12:59 AM
About to take the plunge...final suggestions please, 2.0l stage 4 The Blue Pilot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 11-09-2007 11:01 PM
02 wrx 2.0L stage 2 parts smurfwrx Private 'Wanted' Classifieds 9 07-11-2007 10:24 PM
Carrying an 18G from a 2.0L to 2.5L wrx...worth it? subenerd Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 11-14-2006 04:28 PM
2.0L to 2.5L Wrx Szm426 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-08-2002 09:42 PM
