Old 06-15-2005, 11:58 AM   #1
Stiguy247
Member#: 69301
2xx5 STi-R..
Crystal Grayish Metallic
Default o2 sensor used for wideband vs. reg o2
Is there any difference between the wideband 02 sensor and a regular one on the STi. Is it something that you can by anywhere. Just woundering because I can get 02 sensors really really cheap. Just woundering because maybe I couldjust hook up a volt reader too it and have a cheaper solution to a wideband that is 400 bucks
Stiguy247 is offline   Reply With Quote
Old 06-15-2005, 02:22 PM   #2
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
It's tough to tell what you're asking for in your post. Here's a couple random answers to questions you might be asking though
1) The front and rear O2 sensors on the STi are different.
2) The rear sensor is a standard oxygen sensor - it detects rich or lean and that's it.
3) The front O2 sensor is some kind of planar wideband sensor. It's a different part number on the STi than the WRX, but I don't know if there is any actual difference.
4) You can't plug a "normal" O2 or wideband sensor into the front O2 sensor harness on the STi - the way the ECU reads the sensor is not typical. Only the subaru part will work (unless someone recently released an aftermarket sensor, which I highly doubt)
5) You can probably plug any normal O2 sensor into the rear since it's just a plain heated O2 sensor.
Edit: Also, the corollary to number 4 is that you can't just tap a line on the ECU to get a "wideband" reading from the front O2 sensor because of the way the ECU reads the sensor.
serendipity is offline   Reply With Quote
FS: Front o2 sensor 2000 rs wideband GregBolby 1993 - 2001 Impreza Specific Parts 0 06-04-2008 02:23 PM
can i zip tie second o2 sensor and put wideband o2 in that spot? sidwin AccessPort 2 02-11-2008 06:18 PM
type of sensor the hydra uses for wideband traction issuez Other Engine Management 1 06-05-2006 05:56 PM
WTB: WRX O2 sensor, used or new, from downpipe. SSLegacyGT Private 'Wanted' Classifieds 3 06-22-2005 08:45 PM
Wideband vs Narowband o2 Skidd Engine Management & Tuning 12 02-19-2003 03:59 PM
