Old 06-15-2005, 12:25 PM   #1
AWDSpec
Member#: 82758
o5 WRC
Pinkish
Question Boost, EGT & Oil Pressure Readings
Can someone give me the maximum and minimum warning readings on the Defi BF gauges. ie... Boost, EGT & Oil Pressure Thanks a lot guys.
AWDSpec is offline   Reply With Quote
Old 06-15-2005, 01:50 PM   #2
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
No
Spend 1 Min And Search
Sometimes It Works
kevin2.5rs is offline   Reply With Quote
Old 06-15-2005, 02:11 PM   #3
AWDSpec
Member#: 82758
o5 WRC
Pinkish
You sounded like a smart guy. You really think you're the only one who uses the search option. For your satisfaction, I did and didn't find exactly what I'm looking for. Don't bother posting if you can't give information. Unless you're just trying to increase your posting percentage.
Originally Posted by kevin2.5rs
No
Sometimes It Works
Old 06-15-2005, 04:19 PM   #4
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
How could you not find the info you wanted?
Searching for max, boost and sti found:
EGT readings, second post down.
Searching for max, boost, sti and stock found:
Max boost for a stock STi
Searching for oil, pressure, sti and stock found:
Thread #1on oil pressure
Thread #2 on oil pressure
Thread #3 on oil pressure
If you honestly can't gleam the information you need from those posts, drive your car for a week and note the temperatures and pressures you see and set your gauges accordingly.
AJ711 is offline   Reply With Quote
Wtb: Boost, Egt, & Oil Pressure Gauges lordizzy626 Private 'Wanted' Classifieds 1 02-03-2010 10:40 AM
FS -Chicago- BNIB Omori 60mm. Boost, EGT, and Oil Pressure Gauges KenSekiguchi Interior/Dressup/Audio & Security 25 10-22-2008 05:01 PM
Defi Boost, EGT and Oil Pressure fractur3 Interior/Dressup/Audio & Security 9 11-20-2007 07:17 PM
WTB: Boost , EGT, & Oil Pressure Gauges + Clock Pod BeBop86 NWIC Private Classifieds 28 07-23-2007 03:13 AM
WTT Defi Link boost, egt and oil pressure guages jmj1112 MAIC Private Classifieds 14 04-09-2006 10:00 PM
