Old 06-15-2005, 02:09 PM   #1
Saturn
Member#: 53951
2005 STi
Obsidian Black
Default Wiring Bi-xenon HID's with Halogen Highbeams
I had a set of E55 Bi-xenon projectors retroed into my stock (halogen) headlamps, results of which can be seen HERE
Usually during the day I run my headlamps off and leave my JDM fogs on. The problem I have is that when I need to highbeam someone during the day, when the HID's are off, if I click on my highbeam switch (pull back on the stalk) it causes not only my halogen highs to come on, but it momentarily switches on the HID's as well (with the solenoid on, making them highs) resulting in a flash of HID that's less than a second long.
Now I know that it is very bad for HID's to be flicked on and off, so my question is the following: Is there a way to wire a relay so that when my headlamps are off, if I flick the highbeam switch, only the halogen highs will come on, and if the lamps are on, the HID's will switch like normal?
As of now the wires for the highbeam solenoid are tapped off the stock highbeam wires, which I think is the source of the problem, my assumption is that when the solenoid wires get power, they also power the ballast and ignite the HID's.
Any help would be appreciated.
Saturn
Saturn is offline   Reply With Quote
Old 06-15-2005, 02:20 PM   #2
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
there is. you may may need to dig deep in the archives but its there. I know I saw it here once as well as on the scoobymods.com site.
"low beams off, flash to pass mod" I think. at least that should get you in the right direction.
I did it a couple of years ago, and it works.
RR
Rapid_Roo is offline   Reply With Quote
Old 06-15-2005, 04:33 PM   #3
Saturn
Member#: 53951
2005 STi
Obsidian Black
I searched and was only able to come up with posts that said it was impossible
Old 06-15-2005, 05:38 PM   #4
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
when I get time, I'll see if I can dig it out. It's there somewhere.
shhhhh I better get back to work now.
Old 06-21-2005, 03:55 PM   #5
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
crappy bi-xenon kit wiring mems3 Electrical & Lighting 5 05-21-2009 07:12 PM
F/S Bi-Xenon Projectors with Shrouds (LA) OKR S06 Exterior/Styling 4 11-25-2006 02:13 PM
FS: Audi A6 Bi-XENON projectors with shrouds zuczek Canada Region Private Classifieds 0 09-26-2006 04:28 PM
FS: Hella ECE Bi-Xenon Projectors with Shrouds zuczek Exterior/Styling 17 09-25-2006 02:24 PM
CDN STi with Bi-Xenon benyl Canada Region Forum 7 12-19-2004 12:02 AM
