Old 06-15-2005, 02:29 PM   #1
Kensubguy
Member#: 84082
Default Changing knock sensor
What is the size of the nut/screw holding a 99 subaru legacy knock sensor. I have a new one to change and need to get the right tool for it. Anyone done it?
Kensubguy is offline   Reply With Quote
Old 06-15-2005, 02:34 PM   #2
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
The Bolt has a 12mm head. They're pretty easy to change, as long as you do it when the engine is cold. If you get about a 12" extension and a 12mm socket, that should do it for you.
wrx_driver_2002 is offline   Reply With Quote
Old 06-15-2005, 03:10 PM   #3
Kensubguy
Member#: 84082
Thanks wrx_driver_2002. I finaly bought the sensor after holding out and hopefuly I can do it this evenning
Old 06-17-2005, 10:39 AM   #4
Kensubguy
Member#: 84082
Thanks to all your guidance I have the sensor changed. Do I need to reset the ECU or just wait for the car to figure out.
Old 06-17-2005, 10:51 AM   #5
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
It would be best to just reset it.l
Old 06-17-2005, 11:22 AM   #6
Mgardenier
Member#: 7518
1994 Legacy SS
Aegean Blue Metallic
15 min, in the dark with a slightly warm engine. knuckles not too happy, but night and day difference. and yes, reset the ecu.
Mgardenier is offline   Reply With Quote
Old 06-17-2005, 02:18 PM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Reset it.
ss
subysouth is offline   Reply With Quote
Old 06-20-2005, 02:01 PM   #8
Kensubguy
Member#: 84082
This 99 subaru legacy has very poor take off from stop signs and poor speed uphills. If I have the A/C on the car has a hard time getting up to speed. I have recently changed plugs, wires and fuel filter and now the knock sensor. Is this normal for a 2.2L engine.
Old 06-20-2005, 02:36 PM   #9
Mgardenier
Member#: 7518
1994 Legacy SS
auto or manual?
Old 06-20-2005, 02:51 PM   #10
Kensubguy
Member#: 84082
Originally Posted by Mgardenier
auto or manual?
Auto transmission
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani jakesurfin Engine/Power/Exhaust 9 06-15-2009 01:28 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor jakesurfin TXIC Private Classifieds 4 06-15-2009 01:28 PM
2nd Knock Sensor Location, 2nd Knock Sensor Locatoin! SentinelSison UTEC 3 05-24-2006 10:06 PM
Knock sensor check/change jim747 Legacy Forum 0 04-16-2006 12:54 AM
Changed knock sensor now no acceleration! SubaruLover Normally Aspirated Powertrain 10 08-21-2004 11:59 AM
