Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 06-15-2005, 05:01 PM   #1
Ármann
Member#: 71420
2002 Subaru APS WRX
Green
Question Ground cable ?
Hi.
I'm new to working on my own car, so please don't laugh
Why is it so important to disconnect the ground cable of the battery ?
I'm going to remove my headlights to take out the orange glass that's
around my turn signal bulb and my workshop manual tells me to
disconnect the ground cable.
Well any info would be great, I'm eager to learn
Thanks.
Ármann is offline   Reply With Quote
Old 06-15-2005, 06:01 PM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
It keeps you from shorting out a circuit and blowing a fuse, like carlessly crossing wires when cuttin and splicing or droping and exposed hot wire on a bolt. It also protects sensitive circuits from intermitant connections. Some components don't want to see power and open circuit conditions switching rapidly back and forth. Like when you are tightening a ground wire on a seat-bolt (which I HATE to find when I'm working on other peoples cars. The seat bolt is a cruddy ground more often than not.) It's like taking a light switch and turning it on and off really fast when the bulb is about to blow. Only in this case, the bulb might be your airbag control module.
To work on the CPU I'd pull the neg term, and for replacing starters and alternators as you'll have a large gauge hot wire exposed.
For about anything else I don't bother, but I'm careful and have worked with 12v a long time. Anything with plugs, like radios and tail light bulbs and such, is almost fool proof. But if it isn't and you plug it in wrong with the battery unhooked you won't find out 'til the power comes back on anyway. I'd rather see the spark, hear the fuse pop, know the error and have a troubleshooting starting place.
2phless is offline   Reply With Quote
Old 06-15-2005, 08:26 PM   #3
Ármann
Member#: 71420
2002 Subaru APS WRX
Green
Thanks for the great post
At first all this mechanical work seems a bit complex but I'm a
fast learner so hopefully I won't ruin to many things before I
know what I'm doing
SMP Ultimate Ground Cable System speedmonkee Vendor 'For Sale' Classifieds 15 01-25-2004 01:46 PM
HyperGround System Grounding Cables hiwrx Private 'For Sale' Classifieds 6 01-12-2004 09:16 PM
A few questions about Hyper Ground System (low resistance grounding cable system) bambams247 Normally Aspirated Powertrain 8 08-27-2003 06:25 PM
Are all grounding cables the same? V6 Normally Aspirated Powertrain 2 09-09-2002 09:14 PM
Grounding Cables? PrezzieBaby Service & Maintenance 5 05-02-2002 05:01 PM
