#1 |
Member#: 89295
Vehicle:2004 Daihatsu Sirion Red |
Guys I have read about this grounding mod and I did it to my car, but did I do it correct?I couldn't reach the alternator so I put three wires on the engine.Please take a look at the photos and post any suggestions,thank you. (click on thumbnails for larger images)
p.s: I feel that the car has better throttle response after the mod. ![]() ![]()
#2 |
Member#: 44168
SCIC
Vehicle:2003 Yellow WRX with too many lights... |
Hmm, what kind of car are we looking at here?
#3 |
Member#: 89295
It's a daihatsu sirion...yesterday night was the first time I drove the car for a lot time with the mod.I was very surprised to find out that this mod is working! It really does some job!!
The car throttle response is much better,no more lag, and also it seems to be more alive after 4500-5000rpm! Unbelievable! So I'm assuming that I did good grounding,but what do u think? Can I do something more/better?? ![]() |
#4 | |
Member#: 49895
NESIC
Vehicle: 09 Forester 06 Legacy 2.5i Wagon |
#5 |
Member#: 89295
86?
oh no my friend,I think u r a bit wrong...It's an 1,3litre 102ps 4 wheel drive little car and that's all I've got... any help with the ground mod???Last edited by Sibi; 06-16-2005 at 12:07 PM. |
#6 |
Member#: 44168
SCIC
Well, as long as you're feeling a difference that's all that should matter.
Smoother enging rpms and better throttle response are usually what you'll get out of grounding wires. I can't see the pics at the moment (they're not working or something), but another thing to do is to scrape away the paint on the chassis where the terminals make contact for a better connection. |
#7 |
Member#: 29355
NWIC
Vehicle:2003 GD6 Hate chall but i'mma maintain |
basically you want to ground the engine to the chassis better. the alternator is an electrical backbone, but it's not the only point that should be grounded.
why, may i ask, are you asking a subaru technical forum? |
#8 | |
Member#: 29355
NWIC
EDIT: actually, nice looking car you have there. okay, i had my fun. Last edited by Handsdown; 06-17-2005 at 02:35 AM. |
#9 |
Member#: 89295
Wow,these pics are huge,I have to scrool to read the thread,please resize ore remove them,besides this is not my car,this is the new 2005 sirion that has 86ps and doesn't have 4wd. The previous sirion that I have is the one with 102ps and 4wd. I decided not to buy the shift button version beacause it's slower in acceleration and max speed than the standard version. The reasons I'm asking questions in a subaru techical forum are 1) I found lots of info about the grounding mod in this forum, many people here have done it and I need some advise and 2) I haven't been able to find a daihatsu techical forum!
As days pass and I drive my car more the grounding mod impresses me even more! There is definitely a noticeable performance improvement, I suggest to everyone to try it, I spent 7$ and 15 minutes!! And by the way, this is the little beast I'm talking about!!! (click on thumbnail for larger image) ![]() Last edited by Sibi; 06-16-2005 at 07:51 PM. |
#10 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
Sibi....nice little rig ya got there.......now----we need to fit a turbo to it
#11 |
Member#: 89295
I'm thinking of it,but not now,maybe in 2-3 years time,I only have it 8 months! In Japan this car besides the 1300cc 102ps engine comes also with a 713cc 120ps turbo engine
!!! Unbelieavable! Too bad they didn't import this version in Greece... |
#12 |
Member#: 69343
South East
Vehicle:2000 nothing good slow |
You need to run those wires around the perimeter of the engine bay instead of over the motor. It's not much of a safety issue, but engines get hot and wires are covered in plastic. Being a ground it shouldn't cause any issues but being a ground run right over your positive battery terminal might become one.
Just run them short distances, say a couple from the negative terminal to the chassis, and one or two to the motor, but just near the battery. Then on the other side of the motor, run one or two just from the chassis to the motor. Make sure to get one ground from the engine to the firewall panel. Find your ECU, say in the passenger kick panel or where-ever they put it, and add a ground from it to the body. (unless it's bolted directly to the body in which case it's probably already grounded well.) Neatness is more important than just looks. It's easier to work around, it's less likely to get damaged. It makes troubleshooting easier later on. The list goes on. Good to hear it made a positive difference. |
#13 |
Member#: 57882
Vehicle:2004 WRX WRB |
Ya sou, file. Oraio amaxi.
For Greece, 100 hp is alot relative to everything else in the market. Last time I visited Greece, I had rented a 60hp Citroen Saxo. Slow as hell to me, but average to everybody else. |
#14 |
Member#: 89295
2phless--> Thanks 4 the info.I know that this isn't a tidy install,but I did it temporarily,just to test if the mod works. At least I was careful during the installation and I put the grounding wires in such position that they cannot come in contact with the engine,the only come in contact with plastic parts,so there is no danger.
Today I bought some more wire in order to make more groundings an a tidier install. I'll post new photos when it will be ready! VWGrk1--> Gia xara file! Efxaristw, etsi einai opos ta les! Ante kateva gia diakopes exei oreo kairo edw! |
| Thread Tools | |
| Display Modes | |
| is this gauge mod possible? | cpc691 | Interior & Exterior Modification | 5 | 09-24-2009 08:37 PM |
| Is this o2 sensor ok to use? | jeff1872t | Southern California Impreza Club Forum -- SCIC | 2 | 10-17-2007 03:08 AM |
| Is this IntakeDelete method Ok? | WrxRick | Newbies & FAQs | 22 | 10-20-2005 09:56 PM |
| where is this headlight mod ? | rabbitnutz | New England Impreza Club Forum -- NESIC | 25 | 04-21-2004 09:54 PM |
| Is my grounding mod shocking me? | UGotBoost? | Electrical & Lighting | 10 | 01-21-2004 09:33 PM |
