Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-16-2005, 12:10 AM   #1
josh04
Member#: 89288
2002 Rex
Default Are the Legacy GT engines EJ25D modules?
I was just wondering because i want to do stuff to my 1998 legacy outback and it has a EJ25D. And I wasn't sure if it's the same in the Legacy Sedan.
josh04 is offline   Reply With Quote
Old 06-16-2005, 02:51 AM   #2
tora
Member#: 5851
09 Forester XT
+ NA Miata
which legacy sedan?
tora is offline   Reply With Quote
Old 06-16-2005, 10:48 AM   #3
josh04
Member#: 89288
2002 Rex
THe GT module or if any other subaru.
Old 06-16-2005, 11:29 AM   #4
tora
Member#: 5851
09 Forester XT
+ NA Miata
Well, if it is an 'o5 Legacy GT then no as that is the EJ257, however if you are comparing a 1998 Outback to a 1998 Legacy GT then yes, identical engine.
Old 06-16-2005, 12:00 PM   #5
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
The new GT's (2005+) run the semi-closed deck EJ257 short block. Same block as in the USDM STI! mmmm if I could get my hands on one of those...
xcntrk75 is offline   Reply With Quote
Old 06-16-2005, 12:10 PM   #6
josh04
Member#: 89288
2002 Rex
What about any other years. Or is it just the 98 that are the same.
Old 06-16-2005, 12:25 PM   #7
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
From what I understand, the only diff in same year lagacygt and outback are the tire height, suspension and drivetrain stuff (trans and rear diff). Engine is supposed to be identical. I guess the ecu would be different cause it has to calculate the different ride height and transmission info. But there are a lot of the same parts shared between ALL the subaru models...
janikphoto is offline   Reply With Quote
So how are the Legacy GT trannys holding up? SINthetic Transmission (AT/MT) & Driveline 8 03-15-2005 09:02 AM
So what upgrades are out there for the Legacy GT? Davenow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-06-2004 02:40 PM
Prices are up on the Legacy GT... Billy... Start Talkin'!!! BigElm Tri-State Area Forum 53 04-21-2004 11:38 PM
How reliable are the MY04 WRX engines? Will the car and the engine last long? d-dvr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-10-2003 06:59 PM
does the legacy L have a different spring rate then the legacy GT? iceman Legacy Forum 2 11-18-2000 08:17 PM
