06-16-2005, 12:53 AM | #1 |
Member#: 53352
Vehicle:74 260z |
Dccd or no dccd?
OK, my car will be going for a swap very soon, I was asked by Kevin from garage tuning(great customer service btw) if I want dccd or not, price for it (parts and install) would be around $1000,
if Ill not opt for this, car would be locked at 35/65, so is it even worth installing? or will I be fine with 35/65....Im kinda confused on this, so I wanted to ask the experts PS. I could always install it later, right?
06-16-2005, 06:45 AM | #2 |
Member#: 56791
South East
Vehicle:06 OBS |
get a JDM 6 speed if you don't want dccd, plus they are better transmissions
06-16-2005, 07:12 AM | #3 |
Member#: 41097
SCIC
Vehicle:2005 WRX Aspen White |
From what i've read you can run the DCCD transmission without the wiring and computer to make the DCCD work, all of which can be added later. IMO if your budget allows, get it all done at one time.
06-16-2005, 12:55 PM | #4 |
Member#: 1366
VIC
Vehicle:2000 RS-T -> RSTi-8 Blue Ridge Pearl |
The DCCD tranny have a different transfer case in the back vs the non-DCCD tranny. If you don't wire in the controller, it will be an open 35:65 center diff which is probably fine if you don't run into slippery situation or scenario where you would have one of the front wheels off the ground (rear have LSD so it's less of a problem). Having the Electro-Magnetic center diff (which the DCCD uses) would change the handling since the bias is different from the Viscous center diff.
06-18-2005, 01:11 PM | #5 |
Member#: 32326
NESIC
Vehicle:'04 S2000 Suzuka Blue |
personally i think dccd on daily driven car is a waste of time and money. its a great system but don't use it on anything but very loose surface like snow or gravel. using it on hard grippy surfaces is kinda like towing AWD with a dolly, two wheels on two wheels off is a bad scenario. i'm only now getting into dccd so if i need to be corrected please do so, i'm not one to try and make ppl believe false info.
06-18-2005, 09:11 PM | #6 |
Member#: 1366
VIC
I'm not sure if it's a waste of time and money - 50:50 split gives that FWD push feeling on power, while the 35:65 split would make it more neutral. Some would argue that unless you're on slippery surface you can go without the controller and just leave the EMCD in open mode - I want my AWD and best if I could have DCCD-A
No-dccd center diff fits a DCCD 6 speed and DCCD fit no mater the year of the tranny? | mudbug | Transmission (AT/MT) & Driveline | 24 | 02-04-2019 09:09 PM |
spiider's dccd or other manual dccd users inside | shineynitelite | Transmission (AT/MT) & Driveline | 15 | 02-23-2011 01:13 PM |
looking at 6 speed conversion, but non dccd? or dccd? | jacky599r | Transmission (AT/MT) & Driveline | 42 | 12-04-2008 01:20 AM |
dccd tranny with no dccd box = broken parts | ImprezaRSfan! | Subaru Conversions | 10 | 10-11-2004 06:06 PM |
ABS light and NO DCCD Light | T-WRX Racer | Service & Maintenance | 6 | 11-06-2003 06:35 PM |
