Old 06-16-2005, 03:04 AM   #1
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
Default CEL
when i start my car in the morning (noon) to go to work i have a CEL. all the way to work it stays on. when i leave (8 pm) it isnt on but halfway home it turns on. i havent gotten the code pulled because well im lazy. i just wanted to know if you guys have any thoughts on what it could be. i have 60k miles on the car. there are NO engine mods. none. any thoughts on what kind of cel happens @ 60k with no mods?
svek is offline   Reply With Quote
Old 06-16-2005, 10:44 AM   #2
DreddRS25
Member#: 51642
2008 WRX
Loose gas cap? Did you just fill up recently?
I got a P0483? Fan Rationality Malfunction Hasn't seemed to cause any performance loss, but this seems like something a dealer would need to look at.
I would say get that code read when possible.
DreddRS25 is offline   Reply With Quote
Old 06-16-2005, 11:42 AM   #3
Nanners
Member#: 66306
2001 2.5 RS Sedan
BRP
I threw my first cel at 61.7K miles. Stock with the exception of the brake calipers/rotors.
In my case it was a faulty front air fuel sensor. P0130 which was probably caused by my failure to avoid a large pothole and the CEL hit about 5 minutes after the fact.
Since it sounds like your CEL is a solid light better get used to the "did you just fill up with gas" question as you might hear it a lot...
Kurt
Nanners is offline   Reply With Quote
Old 06-16-2005, 12:52 PM   #4
piker28
Member#: 22664
no offense but people like you(my friend is the same) should be smacked with a rolled up newspaper
get the thing read, it takes like 5 mins, and can help you alot, maybe something is wrong with the car
oh and id have to guess gas cap but i dunno since theres no info to tell
piker28 is offline   Reply With Quote
Old 06-16-2005, 03:37 PM   #5
svek
Member#: 82259
1999 impreza 2.2L
well theres no autozone withing 100 miles of where i live. our local mechanic says he cant do it either. thats why i havent gotten it checked. i just checked my gas cap and its fine. i got the cel when i had about 3/8 of a tank left. the rest of the time there was no cel. im going to fill up today.
Old 06-16-2005, 05:13 PM   #6
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
The downside is, nobody even knows where you live to offer up a free reading, either (your house - where?) If you were willing to meet me locally, I'd do it up, no problem. The newspaper thing is true, though; without a code, we simply can't have any idea. You may as well be asking us how much loose change is in your console!
LetItSnow is offline   Reply With Quote
Old 06-16-2005, 05:39 PM   #7
Hayes
Member#: 11808
Sounds like time to buy a code reader if that's not too much trouble.
Hayes is offline   Reply With Quote
Old 06-16-2005, 08:30 PM   #8
piker28
Member#: 22664
well only half the newspaper thing is true i mean he has no where close to get it read so its not truely his fault
Old 06-16-2005, 09:59 PM   #9
svek
Member#: 82259
1999 impreza 2.2L
ok i updated my location. i filled up my tank today too. still a cel. im going to talk to the dealership tomorow and see if they can do it for me. hopefully they wont charge me any money
Old 06-16-2005, 10:09 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Svekie ol' boy.....the dealer will do NOTHING for free.....unless ya got a boy(girl) on the inside what can fix ya up, like....
....so....if that 'aint happenin'....ya gotsta hook up with somebody whats got a scanner, or shell out for one....a decent one cost ya ~100 clams or so...
...if ya waz closer, Uncle would pull da code and fix what ya got for cheap
Old 06-16-2005, 10:15 PM   #11
piker28
Member#: 22664
just post in your region section asking anyone with one that can help you out, and buy them a hamburger for the help hah
Old 06-16-2005, 10:28 PM   #12
svek
Member#: 82259
1999 impreza 2.2L
damn the dealer. what a bastard. they want $40 for 1 center cap. thats $120 for a set!!
back on topic. ill put it up here and at i-club. the sac & reno section at i-club is pretty good.
Old 06-16-2005, 10:45 PM   #13
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
gas floats man im tellin you
99subi is offline   Reply With Quote
Old 06-19-2005, 12:40 AM   #14
svek
Member#: 82259
1999 impreza 2.2L
ok i got the error code pulled.
p1130
Old 06-19-2005, 12:49 AM   #15
shoeler25
Member#: 52202
2001 2.5RS
That has something to do with the front O2 sensor. Any mods to the car? And Ive heard that a hard hit on the suspension can mess up the O2 sensors.
shoeler25 is offline   Reply With Quote
Old 06-19-2005, 12:55 AM   #16
piker28
Member#: 22664
no he coulda just have it died and youll need to buy a new one and replace it, semi costly but easy to do
Old 06-19-2005, 12:55 AM   #17
svek
Member#: 82259
1999 impreza 2.2L
mods are:
-rear sway bar
-rims / tires
-audio crap
-legacy spoiler
so basically nothing to do with the engine.
edit: what does the 02 sensor do? when it goes "faulty" what consequences are there? do i have to replace it? can i wiggle around some wires and fix it?
Old 06-19-2005, 01:23 AM   #18
piker28
Member#: 22664
replace, if its bad you will get crap gas mileage
Old 06-20-2005, 01:29 AM   #19
shoeler25
Member#: 52202
2001 2.5RS
Correct me if im wrong, but basically the front O2 gets an exhaust reading before the cat, then compares it with a reading from the rear O2 to determine cat efficiency. And it does a couple more things as well. And like piker said, it has most likely just died and needs to be replaced, my comment on hard hits was just a suggestion as to something that could have caused it to die. Since you have no engine mods, it was a possibility, or something got screwed up in the wires, like a short or something. And I believe if the car is running rich that can foul up the O2 sensors.
CEL and flashing cruise control light generalganja Newbies & FAQs 15 01-31-2011 06:17 PM
Need some help please cel plus more!!!! thrasher679 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-04-2010 10:21 AM
Recurring CEL, yet "no problem codes found". Datalogs included karnick Engine Management & Tuning 4 06-03-2010 10:40 PM
Anyone with Borla header and CEL, did the ECU recall fix the CEL? Suba_Roo Normally Aspirated Powertrain 14 01-25-2003 01:53 AM
CEL or no CEL? chuglobal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-25-2002 04:23 PM
